Notacarlo gettin the wheels up @ Noble
1 Attachment(s)
Not too bad for a footbrake lauch on some little 26x10's
Re: Notacarlo gettin the wheels up @ Noble
Is that going to get me sued? Look! Speed Tape!!!!
Congrats! Nice launch!! :tup:
what kind of tires are those on the rear? they look like MT Sportsmans. |
yup he was running sportsman pros
26x10.5 |
those things hook like a champ. I felt like the red headed step child at Noble, being the only one there with 26" tires. I had them down to 9 psi per Wide Open Phil and things began to happen right.
If you listen to my 21.1 pass all you can hear is the M/T SP whining away. Why 26" tires? I have no idea. I call it failed research and habbit. This car has had 26'ers forever and a day. We will see if Santa stocks 28x10.5x15's. |
I contemplated going with a set of Sportsman Pros. It does look like they were working well for ya!
now...I may be on the verge of hi-jacking this thread, but..... what's the big deal with 26" tires?? I know *some* guys run taller tires, but I thought it was better to stick with the stock height (26") because that's what the stock ring and pinion and transmission were setup to work with, no? Rob |
All I know is that there were people running similar times as me with a buttload better MPH. I was also at 5350-5400 RPM at the traps. I would like a little more to play with and I think a 28" would deliver.
I am also told that the 28's hook better. I will run these until their death and then try a set of 28's for comparison. |
Let's get the tire chat into the proper area, please... :nono:
any updates on this GN Dan ??
