Stock or stage one
I was wondering what the max HP you can safely get out of a stock block VS a stage one block??
Re: Stock or stage one
The Stage 1 block wasn't all that much different than a stock block except for a bit more beef down in the mains and such. Over the years the stock block has had things like steel main caps, girdles, etc. developed for it that allow for more bottom end stability. The difference in HP capacity (for same displacement anyway) is pretty much zero if built right. Stock block cars have been into the 9s at almost full weight ...
One of the big difference is the clamping force available with the extra bolt holes in the heads on Stage blocks, but even that has solutions on the stock block. Stage TWO blocks are significantly stronger, but usually are for high dollar super high horsepower race set ups. TA Performances aftermarket block is really the "trick" piece in that sort of setup now (and you can get some really big displacement out of it ... like almost 300 cubes!) |
Can the steel main caps, girdles fit on a stage one? I want to build a high 10 summer cruiser. I want it to last longer then a couple passes but want it to look as close to bone stock as I can.
A stage one block will need four bolt caps. A stock block with steel mains and/or a girdle will meet your goals. Probably cheaper too.
There's a much less expensive way to go about it if you feel like doing it. The Series II FWD engine has been put in a RWD F body cars and there's an adapter for the bellhousing so you can put a conventional RWD tranny on it. I know of one that has been put in a GN and with very few mods to the long block it's already been in the 10's with decent gas mileage. The Series II engine is the poor mans stage based block with cross bolted mains and very good flowing heads. You can still get them cheap out of a scrap yard and fab all the parts plus adapt the ECM from an F body for less than a Stage block or even putting billet mains or a girdle on a RWD block.:six:
I would not bother going with a F-body ECM. If you are going this serious, I'd just make the jump to XFI. |
You read my mind ... I was going to ask about all the accessory drive stuff. Since the front cover is the same, does the stock aluminum "mega bracket" all bolt up? Or do you have to redo everything?
I think waaay back someone did do that (maybe Thrasher?) But it became pretty high dollar pretty fast and there were still Stage II off-center blocks and heads available. Bowling Green had an intake they made too ...
Now you have TA Performance with the custom block and heads that can be made into a SERIOUS race motor of almost any displacement for the big dollar setups. The street stuff can be made to go mid 10s all day long with ported iron heads or aftermarket aluminum with a stock block with steel mains/girdle. And Fullthrottle had a stroker kit available (don't know if they still do). The real budget build for awhile there was to get an old 14 bolt oil pan 4.1 and use that ... for a long time they were pretty cheap, the extra cubes made it easier to build torque and if you split one down the middle you got another $50 block and did it again. :) |
