need help on 85 T type. no start
After being stored for about 18 months I tried to start my T type. Checked for fire with sparkplug on top of engine. good spark. sprayed ether in throttle body and nothing. removed a spark plug and sprayed ether in cylinder, replaced plug and tried. It fired one time (obviously only once) fuel pump is running has good compression, what to check next? How to check fuel pressure?
Help Help Marshall |
Re: need help on 85 T type. no start
It could be your fuel pressure regulator. It could be your injector signaling, no pulses to your injectors, no fuel to the cylinders. |
