-   Engine Electrical/Ignition (http://gnttype.org/forums/forumdisplay.php?f=5)
-   -   What size is Alt wire? (http://gnttype.org/forums/showthread.php?t=12327)
carbreaksalot 02-20-2009 09:41 PM
Is it 8 gauge? Also can I upgrade this to 4 gauge, if so how many volts can I get out of it?
Keller 02-21-2009 01:57 AM
Re: What size is Alt wire?
Caspers makes one that uses 6 ga. that is designed for high amperage (175-200) alternators. So wire at least that large has been used. I suppose 4 ga. may work, but will be harder to make the turns.
Standard voltage should be ~13.6-13.8. Using a voltage boosting device would net more. But those usually are only in effect under WOT and boost.
