check engine light flashes on startup
after changing my MASS sensor my check engine light flashes twice every time i start my car it did not do this before i changed MASS the MASS is an oem replacement from kirban is this normal
Re: check engine light flashes on startup
MAF? (Mass Airflow Sensor)
The CEL is usually on until the engine is running. (Over 400 RPM) I believe it is normal for it to be on, and maybe even flicker once before the engine is cranked. Perhaps there was a problem that was corrected by the new MAF? |
glad to hear that i was kinda worried that some other problem may have reared its ugly head
