Cool???
installed 160 T STAT today but fan still not kicking on until 210 then cools down to 196 fan shuts off then 205-207 its back on could the fan switch be bad...
Re: Cool???
Do you have a chip set to turn the fan on at a lower than stock temperature?
Are all of your fan relays working? Does it only come on "high", or low at first? |
Re: Cool???
high so i guess a relay is bad... |
Re: Cool???
No. The fan is turning on when the stock chip is telling it to turn on at a higher temp than 160. Just like it is supposed to.
If you want to have it run strong, get a chip. Not the OEM 25 year old chip. |
Re: Cool???
the fan is not the one that came on car factory im sure...it has a adjustable temp/fan on /off on it....160-230....there are 4 sockets as here
+....hot {used} G....grnd{used} m....dont know{not used} C.....{USED} DONT know what this lead is but one of the three black wires off my fan harness is in this spot...does anyone know what this wire does as i did not hook this wire back up to the aftermarket fan i installed.?? the above is for the fan i removed not the one i installed......so i only used the + and - on the new fan |
Re: Cool???
thats ok i found out that the "C" is for the ac control of the fan...:):innocent:
Re: Cool???
Might be a good place to wire a 'force fan on' relay and switch to insure the car runs cooler.
