84-87 GN and T-type Parts
Stainless TH style down pipe 3" $250
84-87 Header panel (GM not aftermarket) (T-type) $150 blackout wheelwell trim $50 each 109 Block $300 std/std crank $325 .010/.010 Turbo crank fresh from the machine show $375 .020/.020 Turbo crank fresh from the machine shop $175 stock 8445 heads needing rebuild $40 a set 84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85 to 87) $1400 BQ coded GN transmission 48k $300 Stock 200 4r tranny pan $35 Oil cooler adaptor with nut $35 Timing cover $25 Turbo rods(2 dot) $40 a set of 6 Turbo flex plate $25 Turbo oil pans $30 each 84-85 stock turbo 84-85 ECM $50 84-85 control module $50 84-85 up pipe(stock) $40 84-85 up pipe(after market) $40 84-85 Stock Turbo $200 Steering box $40 GN sway bars $30 each windshield wiper assembly $15 Complete heater box $150 Manual antenna assembly(mast, base and screw) in blackout$40 Non Key locking t-top $90+shipping for the set GN tail lights with blackout trim $100 Quarter glass with blackout trim $70 3 piece windshield blackout trim $30 3 piece rear window blackout trim$20 Any other black piece e mail me GN hood $95-$150 86-86 GN plastic inner fenders uncracked $75 each AC lines $45 Turbo shield $30 84-85 GN intake $40 86-87 fuel rail $35 84-85 fuel rail $25 Any year injector harness $30 84-85 valve covers $35 86-87 valve covers $35 cam position sensor just the lower part(no cap) $25 84-85 MAF $45 84-85 turbo adaptor $25 84-85 crossover pipe $35 84-85 Alt $30 8445 heads $40 a set 84-85 engine wire harness $145 86-87 engine wire harness $175 Any other harness on the car e mail I have them all Blue dash pad $120 Chrome and gray strips on upper door panels $25-$35 each piece depending on condition I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard top . Nice grey arm rests $15 for both Nice blue passenger visor with lighted mirror $25 Gauge surround $35 radio surround $25 Stock GN radio $50 T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6 pieces $100 87 GN steering box $40 E mail me if you need a part not listed Fortune628@aol.com I most likely have it. or CALL ME at 413 746 9668 |
Re: 84-87 GN and T-type Parts
Take to the top
84/85 Turbo $200??????Mine is shot,Is this one complete,un-molested,and useable?I am only interested if it is Complete,ready to bolt on.Thanks Mike PS you will have to post here or PM me.E-mail is not set up yet.
The 84/85 turbo is complete and can be bolted on and run. nothing wrong with it.
long block?
I'm looking for an unmolested hot air long block, that will be rebuilt. GOT ONE?
I have a long blockwith 48k, std. crank that looks very nice, I changed the rear main seal and timing chain, its still on the engine stand, the original timing gears had no teeth missing from timing gear, I still have it. If interested my e mail is Bobhebert574aol.com .
Take to the top
Send me a pic of the complete turbo.Is it blowing smoke?What does the end play feel like?I just don't want to spend money on a turbo that is going to fail the same year I get it.Thank you much.Oh is the price negotiable?Shipping?
It doesnt smoke, has very little play. What e mail address do you want the pictures sent to?
Hi Bob,PM is sent,sorry I didn't update my email when it changed.
