GN and T-Type Performance Enthusiasts (GNTTYPE) Forums (
-   Engine Electrical/Ignition (
-   -   Balancer Timing Grooves (
CJ87T 03-06-2016 04:10 PM
Why are there two timing mark grooves in the harmonic balancer on my 87 T? Also the degree indicator tab has a zero mark and there is a visual timing sight tube right next to it. What's the deal? Thanks.
larrym 03-09-2016 06:12 PM
Re: Balancer Timing Grooves
one has been added by some one as a mark for setting the cam sensor.
I did the same to mine when I had the motor out, the first one should be the TDC mark the second should be 25 degrees ATDC
