What Color Is The 85 Gn Headliner?
I need to replace my headliner. What is the exact color name? Thanks- Brad
85GN, Hk exh., 2 1/2 int. DP(no TB elbow) 42.5 inj., adj FP, Walbro 340 hot wired, adj waste, 87 ECM, F-body rad, dual electric fans, 87 IGN HW, TT chip, Alky. Port & MAT heads, TA33C Turbo., powerlogger, WB O2 , 2800 SV., MT DR, 18 lbs boost. |
Re: What Color Is The 85 Gn Headliner?
Go to any competent interior shop and they should match it pretty well i would just oversee what color gray they put on, in my case they pulled out 4 different color liners and i chose one that matched pretty well and looks great, BTW i don't think they make the original fabric but you may want to check gbodyparts or some others they may have repros that are very close.
87 gn stock turbo, adj. waste gate act, hot wired 340 warlboro pmp, accufab reg., 42lb inj., 2 fan set-up, kenne bell cold air, smc alky kit, 2800 l/up converter, tt chip, scanmaster, not track tested heck not out of my garage shes gettin a makeover. |
