Old 05-15-2015, 05:55 PM
gbody5's Avatar
gbody5 gbody5 is offline
gbody5 is on a distinguished road
Default Valve Cover Gaskets
Time for some TLC for my GN, one thing on my list is new gaskets, any recommendations?
Thanks!
Mark
87 GN 52K, Walbro 307-HW, Powerplate, Cold Air Kit, Adj. Wastegate, TB Bypass, 160 T-stat, ATR Exhaust, MOOG 5660/5409 Springs, Bilsteins.
85 MCSS
85 442
88 Corvette Roadster
09 G8 GT
Old 05-16-2015, 05:49 AM
Default Re: Valve Cover Gaskets
Hi Mark, I put some new valve cover gaskets on and I highly recommend RJC racing products. Their web site is www.RJCRACING.COM or to place an order use the website www.RJCRACING.NET. I have been very well pleased with the valve gasket cover material they use compared to cork gaskets. These will fit your stock valve covers perfectly. Just make sure to torque them down to correct specs.
Jamie C.
Old 05-18-2015, 01:25 AM
Exclamation Re: Valve Cover Gaskets
I think the standard cork gaskets are fine. Just remember that none of them are cut to fit the stock aluminum valve covers correctly and they will require some trimming.
Old 05-18-2015, 03:03 PM
RJC racing gaskets fit perfectly with no trimming needed. No matter what gasket material you decide to use the main thing is that with proper torque specs you shouldn't have any leaks.
Jamie C.
Old 05-22-2015, 08:57 PM
gbody5's Avatar
Thanks for the advice, new radiator from ALRADCO going in first, funny how priorities change
Mark
85 MCSS
85 442
09 G8 GT
