NEEDED: Power antena relay wiring harness plug
Sorry to post this here but posted it in the Parts Wanted section and have had no replies at ALL! I know there must be somebody out there that has an '86-'87 Regal that has this plug.
I have everything I need to install a power antennae in my car (antennae, mounting bracket, cable to relay, antennae to radio signal cable, and relay), but need the plastic connector plug and wiring from the dash harness to the relay. The one I looked at in my T-Type is white plastic (one from the antennae is black), has three wires (orange wire goes to constant 12V source, pink one goes to radio, and last one is the ground). This is the connector I need to finish the job. Any one out there have at least the plug with wires cut (would prefer the wires as long as possible)? Let me know! Thanks, Bruce
'68 el Camino SS 396 4 Speed, 3.31, Buckets, AC '72 el Camino SS 454 4 Speed, 3.73, Buckets, AC '75 el Camino SS, 400 SB, 200R4, 3.42 LSD, AC, Swivel Buckets, PW, PDL '87 el Camino SS Choo Choo (305 TPI, 200R4, 3.73 LSD) '87 Buick GN Hardtop |
Re: NEEDED: Power antena relay wiring harness plug
Bruce, Have you called Caspers Electronics to see if they can help you with a proper end and wiring??? Tom G.
Thanks for the suggestion. I think the only place I am going to find this is from someone who has a car ('86-'87 G-Body) that has the right connector in the dash wiring. Anybody? Bruce
Got some time Frdiay morning to run up to a junk yard that I thought would have some cars in the '80's. Got lucky and found an '86 Grand Prix with power antennae.
Got the wire out in about two minutes, brought it home, installed it in the Choo Choo and guess what, my '87 el Camino Choo Choo now has an eletric antennae from an '86 Regal. KEWL addition!
This might be worthy of a writeup, no?
Something like a "How To ....... Install a G-Body power antennae in other G-Bodies"
Sounds like it might work....too bad I did not take any pictures What did you have in mind Scott?
