Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > FAQ and General > General Turbo Regal Questions
Old 02-05-2009, 08:57 PM
Dan SS2471 Dan SS2471 is offline
Dan SS2471 is on a distinguished road
Default Upgrade choices / suggestions?
Here is the car's current setup:
Engine/Exhaust:
-rebuilt about 3k miles ago
-204/214 cam - flat tappet
-ported stock heads
-steel center main caps
-double roller timing set
-020 forged JE pistons
-60# mototron injectors
-hotwired Walbro
-3" LT-1 MAF with translator
-TurboTweak chip
-160* t-stat with billet neck
-Caspers cam sensor cap
-3" ATR downpipe
-Turbonetics Evolution wastegate with in-car adjustability
-test pipe with cutout
-Hooker 2.5" catback
-Rebuilt G-80 rear
Stock turbo set @ #18s max right now, stock trans and converter.
Can't make any baseline passes because the trans needs to be rebuilt. Or I should say it's flaring up at WOT and when it warms up it hesitates to shift on th 2-3 and whines a bit.
My ultimate goal is to have a street driven, high 10 - low 11 second car that will see the track a few times a year.
As far going forward, I'm assuming if I go bigger turbo, that the way it's currently configured, that it's got sufficient fuel...? Based on my goal, what would be the required or optimal turbo / converter combo? Also, if I do the converter while doing the trans, will the car still be streetable until I do the bigger turbo?
Based on the re-build specs, how much boost would be considered to still be 'safe' assuming the engine is tuned correctly. Based on what I've read, it seems to be a good starting point to reach my goal. I realize the turbo/converter aren't the only thing that it's going to take but figured they'll be the biggest contributors at this stage.
Thanks in advance.
Dan
Old 02-05-2009, 11:41 PM
Default Re: Upgrade choices / suggestions?
with what you currently have, and a WCC converter,decent stock location intercooler or front mount and a PT67/76 ball bearing turbo @ 20-25 psi you car will run into the 10's
this is all of course with good tunning, traction, etc....
I have built two cars with mostly the same stuff you have listed and both have run 10.5- 10.80 range.. on pump gas with an alky system..
Old 02-05-2009, 11:59 PM
Exclamation Re: Upgrade choices / suggestions?
A single Walbro is VERY iffy for your expectations.
Old 02-06-2009, 12:11 AM
good call Scott, the cars i built were also using "double pumper" fuel pumps..
Old 02-06-2009, 12:13 AM
PaceCarTA PaceCarTA is offline
PaceCarTA is on a distinguished road
you can go plenty fast on a single if you add in a good alky system like razors dual nozzle
a car i work on here went 10.18 129 on a single intank walbro (340M from racetronix) with a razor dual nozzle pushing with a 70bb and 83 injectors (of course nowhere near max duty ) on a full cage car weighing about 3700lbs with driver oh and on 93 octane , footbrake launch, stock ecm with a TT 5.6 chip
stock fuel lines too
mellissa went 9.90 on a single , stock lines and rails along with dual razor alky kit
Paul, - www.MAGNAbuick.com -
the 87 -GNx'd
the 86 -GN 71GTQ FAST th400 PTC 9.81 @137.68 1.46 60' 93 and alky
the 87Ttop-Gn 74gtq XFI TR6 200-4r PTC caged
http://www.streetfire.net/video/86-b...as_2425180.htm
Old 02-06-2009, 12:32 AM
i know all about Grumpys combo, and i know it can be done on a car using alky..
But having two "intank" pumps is a good safe guard
Old 02-06-2009, 09:14 AM
Thanks very much, guys.
As far as the trans..while it's being rebuilt, are there any considerations there or is the stock 2004R beefy enough on a rebuild to handle all of this?
Dan
Old 02-06-2009, 02:03 PM
No.
Sorry, but as Phil commented earlier, you will need a trans build with some billet parts to handle 550-600 HP target you are shooting for. And a converter set up for the task as well. A stock trans and converter won't last long at all with your proposed setup, let alone what you already have.
FWIW, general pointers to buildups are found in our "recipes" on the website. And questions regarding different aspects of the car should preferably asked in their respective areas. Or answered searched for in those areas.
Old 02-06-2009, 02:10 PM
No.
Thank you, Scott. Recipes and correct forums noted. Sorry about that.
And thanks for the info.
Dan
