Old 10-07-2006, 03:13 PM
rock1057's Avatar
rock1057 rock1057 is offline
Rock1057
rock1057 is on a distinguished road
Send a message via AIM to rock1057
Default need some advice, 60/65 High Imp. Injectors
Is this enough injector for a turbotweak chip running a pt70 p trim with .63 ex housing? Looking for a good streetable turbo. Unsure is the pt 70 ok on the street with a 3300 stall or is there a better turbo for quick spool that makes about as much power? Only want to run in the tens once and be able to hit the low to mid 11's easily. Any help would be greatly appreciated.
1987 GN consists of maxed out iron heads, off the shelf cam, beafy 2004r transmisson, pt67 turbo, forged k-1 rods and eagle crank, block girdle, 75 lb injectors, fast bank to bank.
Old 10-08-2006, 09:47 AM
Default Re: need some advice, 60/65 High Imp. Injectors
The injectors will be fine down into the 10s (well into the 10s, depending on the car's weight). You can probably sneak into the upper 10s with a 61-63 (or equivalent) and have something that's really streetable with the right converter. A 70 is going to need more converter ...
Old 10-08-2006, 12:36 PM
Exclamation Re: need some advice, 60/65 High Imp. Injectors
Remember - Chip must match injectors!
Old 10-09-2006, 02:45 AM
rock1057's Avatar
Rock1057
So both of you think that the 60/65 injectors would be fine on a pt70, I think I will go with a 66 instead to be on the safer side. Whats your guys thoughts on this?
Old 10-24-2006, 02:56 PM
Overboost's Avatar
Overboost Overboost is offline
Hammer Time
Overboost is on a distinguished road
I have a TE60 turbo with the 65LB injectors, GINOURMOUS intercooler, 3200 stall and stock trans, turbo tweak chip but I am only in mid 12's. hoping soon to fix that with some trans tweaks. I run rich no matter how fast I am going. still tweaking on that also...
