Tons of GN and T-type parts
-All prices do not include shipping, unless stated.
-GM crate motor 350 block # 10066036 4bolt mains Edelbrock carb and intake, headers, comp cam 1.6 rockers etc. $800 -nice set of 85 Maroon bucket seats $300 -Brand NEW still in the plastic 85-87 GN Front PUI bucket seat covers(drivers and passengers seat, upper and lower) $300+shipping or picked up -New ABS Rear Bumper fillers $200 -87 Grand National Engine 100% complete, runs great $2500 -TR Custom New style Big mouth cold air kit,chrome has some small spots of rust but its in over all good condition NS its conplete $80 shipping included within the US -New tranmission shifter cable(after market) $18 -Hot Air(84-85) conversion kit to Intercooled(86-87) $1800 Includes almost all the stock 87 parts needed to convert over to intercooled, E mail for parts list -Turbo Riviera Turbo $200 -109 turbo block std bore $300 -Good std/std turbo crank $300 -8.5 Posi unit from a 87 GN $225 -86-87 Engine wire harness(no injector harness) $200 -86-87 Intake manifold(lower and dog house) thats been painted $160 -8485 GN front air dam $50 -New after market cruise control shifter lever $30 - Dutt style drive shaft loop $20 -Dash plaque for a GN in driver condition $40 -86-87 stock turbo, very little play $200 -84-85 stock trubo, very little play $150 - 84 GN front and rear seats(leather and cloth) need to be recovered $200 -86-87 T-type rims(no center caps) $300 for 4 or 1 for $100 -BRF 200 4r $500 -NOS Turbo 6 emblem $50 Free shipping -Autometer Boost gauge with A pillar single pod $25 -86-87 original MAF(not Rem.) $90 -86-87 AC compressor $75 -86-87 Belt tensioner $100 -87 Intake manifold(lower intake and upper dog house, with metal waterlines) $200 -8445 heads Rebuilt with around 20k on them $100 -87 Engine harness with inj harness $230 -Turbo shield $40 -Rad hold down plate $30 -Front license plate bracket $20 -86-87 Air dams $65 -Doors $400 for set(1 pass and 1 drivers) they are manual windows and manual locks have just the start of surface rust on under side. Pick up only, I wont ship these. -Vac brake set up $100+shipping(master cylinder, power brake booster, and correct pedal) -87 442 Passenger side New rear quarter -Make Offer -gray 87 442 bucket seats $250 -locking T-tops $200 a set -84-87 RegalT-type header panel(has hole for emblem) with good black paint $200 -84-87 Nice Header panel (Hole for emblem has been filled) $200 -GN driveshaft $75 -Stock 109 Turbo long block(120k) $1000 -87 GN 109 short block, .040 Cast pistons, .010.010 turbo crank, never run $800 -86 NA 3.8 Engine complete runs good has 109 block $350 -84 NA 3.8 Engine complete runs good 290 block $250 -84 turbo Regal block .030 over $150 -85 Turbo Regal Block .030 over $150 -109 turbo block std bore $300 -109 turbo block .030 over $150 -109 turbo block .060 over $100 -Turbo crank(StdStd but will need to be turned at most .010.010) $250 -Under drive crank pulley and alt pulley $40 -86-87 T-type center caps(Tri shield) $40 Each -86-87 T-type wheels(set of 4) no center caps $300 -85-87 GN steering wheel $100 no horn ring center -Nice set of GN tail lights with blackout trim $160 -84-86 GN Power seat track assembly $150 -Floor brackets for console $30 -Regal doors(They have very little surface rust on under side) $150 picked up only -Floor pan for bucket seat car $150 picked up only -Rear quarter $150 each picked up only -Rear frame rails $100 each -Front frame rails $100 each -Control arms(Front lower)$60 -Control arms(Front upper)$30 -Motor mounts(metal, frame mounts) $35 -Turbo crank(.010.010) in nice condition $200 -Turbo crank(StdStd but will need to be turned at most .010.010) $250 -NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35 -84-85 Flex cooling fan $10 -85 Power steering pump(For car with power master) $30 - trans cooler $20 -B body spindles $50 for pair -85 Maroon bucket seats $200 good condition -85 Gray bucket seats $250 good condition -Crank window regulators $50 for both doors -Dash vents(with nice chrome) $20 each -Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both -Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75 -Visors good for cores(non mirror) $20 a set -Chrome marker light $35 each -Both front head light bezels(need to be painted) $70 for both -Rear center filler(The part that the rear license plate bracket attaches to) $30 -Pass remote mirror bracket(Just the bracket that attaches to the dash) $15 -NOS black plastic seat track cover for rear right side(GM part # 20023766) $20 -Frame in good condition $200 -heater box shield $15 -84-85 Shield to cover heat hoses $15 -bumperette rubber strips in good condition(used GM not after market) $20 each -Stock factory lighter $8 -Stock Battery hold down $10 -Connecting Front Brace $25 -Front frame braces(underside) $25 -Plastic Brackets to mount front air dam $30 for 2(For both sides) -Good hood shocks $10 -Stock turbo inlet bell $20 -86-87 engine hoist bracket(on intake) $20 -87 gray cloth Limited front and rear seats $200 -87 gray column (shift on column) $100 -87 Split bench seat power seat track assembly $100 -Original GN Quarter extensions for car with spoiler $40 -84 Red upper door panels $80 minus chromegray strips $50 -Grey T-type upper door panels no chrome strips $50 -87 Maroon upper door panels $50 -Drivers side Blackout head light bezel $40 -Chrome head light bezels painted black $40 for both -Black trim Marker lights $40 each -Blackout wheel well moldings $60 each -Chrome(Regal) wheel well trim moldings $45 each -84-87 T-type header panel with hole filled $150 -84-87 T-type GM header panel, has some small imperfections $125 -84-87 Grand National GM header panel, has imperfections $125 -Passenger remote mirror(needs paint) $60 -87 GN seat belt set(10 pieces) $120 -84 GN steering column with tiltcruise $150 -Maroon steering column with tiltcruise $150 -87 GN grey column with tiltcruise $150 -87 grey column(shifter on the column) $100 -84 Blue column(shifter on column) $100 -84 tan bucket seats $250 with rear seats $300 -86 blue 86 442 bucket seats $200 -85 Gray 442 bucket seats $200 -Gray Monte SS bucket seats $200 -85-87 Gray concert sound lower door panels $100 -GN Dash Plaque $75 -84-86 T-type dash plaque $50 -86-87 Upper intake(dog house) $30 -86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100 -86-87 bare throttlebody $40 -86-87 Up pipe $25 -86-87 Cruise control assembly $40 -86-87 Water pump pulley $25 -86-87 Main accessory bracket $70 -86-87 Y bracket on back of Alt $35 -86-87 Flat Y bracket on front of AC compressor $35 -86-87 Intercooler brackets $25 each -86-87 Coil bracket ( The horse shoe shaped bracket) $30 -86-87 Power steering res. bracket $20 -86-87 Power steering pump $70 -87 GN Electric fan $50 -84 rad shroud $30 I have every piece for 84-87 GN engines(stock) E mail if you dont see it. -86-87 T-type wheels $100 each -84-85 Non key locking t-tops $150 a set -Astro roof complete assembly with wire harness, switch etc. $200 wont ship -Bigger then stock front sway bar $70 -Fuel senderfuel hanger(analog gauge) $60 -BQ tranny $250 -Rebuilt BQ tranny $400 -D-5 convert $75 -87 chrome grill painted black(looks good) $100
MODERATOR on Turbobuick.com |
Re: Tons of GN and T-type parts
ENGINE PARTS: ------------- AC compressor(84-85) $40 AC lines(84-85) $40 Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20 Adaptor(85 Turbo to intake adaptor) $40 Adaptor(Oil cooler adaptor with nut) $35 Air Cleaner scoop(86-87 Scoop for airbreather) $20 Air Cleaner assembly(86-87) $25 Air Cleanerassembly(84-85) $20 Alt.(86-87) $60 Alt.(84-85) $30 Balancer(Turbo harmonic balancer) $80 Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20 Block(109 Block) $250 Cam position sensor just the lower part(no cap) $30 Cam position (sensor with cap) $65 Coil pack(84-85) $40 Coil pack(86-87) $25 Control module(84-85) $50 Connecting rods(2 dot) $40 a set of 6 or $10 for 1 Crossover pipe(84-85 Exhaust crossover pipe) $35 Dip stick and tube(86-87 dipstick and tube) $50 Dip stick and tube(84-85 dipstick and tube) $30 ECM(84-85 ECM) $40 EGR plastic cover $5 Elbow(84-87 Turbo elbow) $25 Flex plate(84-87 Turbo flex plate) $25 Fuel rail(84-85) $25 Fuel rail(86-87) $40 Heads(stock 8445 heads needing rebuild) $50 a set Injector harness(84-85) $35 Intake manifold(86-87 Upper intake manifold)$35 Intake manifold(84-85 GN intake) $40 Intercooler $45 Intercooler brackets both for $40 MAF(84-85 MAF) $40 Main accessory bracket(86-87,the big alum. one) $70 Main accessory bracket(84-85) $40 Motor mounts(metal, frame mounts) $35 Oil pan(Turbo oil pan) $40 each Power steering pump(86-87) $70 Pulley(86-87 Water pump pulley) $25 Pulley(86-87 Alt pulley)$20 Rock arms+shafts(stock, complete set) $35 Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40 Throttlebody(86-87 Throttlebody bare) $35 Throttle bracket(84-85 Throttle bracket) $20 Throttle cable(84-85 Throttle cable) $30 Timing cover $35 Valve covers(set of 2) (84-85) $30 Valve covers(set of 2) (86-87) $50 Vapor cannister $10 Wire harness(84-85 engine wire harness) $150 --------- INTERIOR: --------- I have every color interior part including green. Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2 Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both Concert sound speaker covers(84 GN) $50 Console shifter plate(Plate on console that goes around the shifter)$25 Dash pad no cracks(grey or Maroon) $120 Digital dash gauge cluster $200 Door panels(85-87 GN lower door panels) $60 Door panels(85-87 T-type grey lower door panels) $40 Door panels(85-87 T-type Maroon lower door panels) $40 Door panels(85-87 T-type Blue lower door panels) $40 Gauge cluster(Analog) $100 Gauge cluster(Digital) $200 Radio(Stock GN radio with cass, no EQ) $40 Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both Sail panels(Grey interior panels around the quarter windows) for Hardtop car $40 for both Seats(87 GN Front bucket seats need recovering) $200 Shifter $35(84-87 GN, needs T handle) Steering wheel(good to have recovered) $40 Steering wheel(Tri shield GN horn center $40 no ring) Steering wheel(T-type horn center $30 no ring) Steering wheel(T horn center $30 no ring) Surround(Gauge surround) $30 Surround(radio surround) $20 Third brake light(Grey, red, Maroon, or blue Third brake light)$20 Each T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue $25 for each piece ------------ Body Parts: ------------ Blackout trim for front windshield $30 each piece or $75 for all 3 Blackout trim for rear window $30 each piece or $50 for all 3 Blackout trim around the door windows $30 each piece Blackout Drip rails(hard top) $50 for both Blackout(Trunk Lid blackout trim piece) $40 Blackout trim, T-top boot shaped trim that the T-tops lay on $60 for both Bumper(GN Rear black bumper) $100 Bumper reinforcement(Alum. Front bumper reinforcement)$90 Bumper reinforcement(Alum. rear bumper reinforcement) $70 Front bumper shocks $25 for both Rear bumper shocks $25 for both Fenders(84-87 GN fenders(GM)) $100 each Grill 87 GN Grill $200 Grill 86 T-type grill $50 Grill emblem(87 , says "Buick") $15 Hood(GN hood) $150-$250 (pick up only) Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50 Lock set(all 3 locks with key) $30 Mirror(Drivers mirror) $20 Mirror(Passenger Mirror,non remote)$20 Mirror(Passenger Mirror, Remote) $65 Quarter windows with blackout trim $150 for both sides Tail lights with blackout trim $160 tail lights with chrome trim $80 T-top boot shaped trim that the T-tops lay on $60 for both Wheel well(Drivers Turbo plastic wheel well) $100 each Wheel well(Passenger Turbo plastic wheel well) $150 each Any other blackout piece e mail me I have them all --------- Misc: --------- Antenna base nut and spacer for Power antenna with black trim $10 Control arms(Front lower)$50 Control arms(Front upper)$30 Gas Tank(Turbo gas tank) $40 WON'T ship pick up only Heater box(Complete heater box, For AC car) $120 Heater box shield $15 PowerMaster to firewall adaptor(bracket) $30 power trunk mechinism $20 Steering box(87 GN Power steering ) $35 Sway Bars(GN sway bars) $25 each Transmission cross member $40 84/85 Tranny dip stick and tube $40 86/87 Tranny dip stick and tube $45 Transmission oil pan(Stock 200 4r tranny pan) $25 84-85 T-type wheels $40 each or 4 for $120 windshield wiper motor $40
Hey Bob
Looking for exhaust parts eveything behind the collector minus the Cat. |
Interested in an 86/87 power steering reservoir if it is the "2nd" style one.
Will you be at the GS Nationals?
Do you need the one with the bigger reservior? I will have t look. I still have a few in cars that.
Sorry I dont have any good exhaust systems. Most of the cars Ive parted have rust stock exhaust systems.
I would be interested in the brake setup and complete power antenna setup with the spacer[black] if in working condition.
Also looking for pass door edge guard[black] if you have one. Last edited by robzombie4551; 11-03-2012 at 10:32 AM. |
Don't think there was ever a change in reservoir size. There was a 2nd design that was part of a recall for power steering "groan". Adjusting the angle the in/out lines mate with the reservoir base was the fix. I can shoot a pic of the 1st and 2nd design ones if you'd like.
Is the reservoir you need, the res with cap that turns on clockwise or counter clockwise. My e mail is Fortune628@aol.com if you want to send a picture of the res you need.
I have the vac brake set up, whats your zip code to get a shipping quote.
