Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Add-on Electronics and Electrical > Scan Tools
Old 07-31-2012, 04:45 PM
turbo84gn's Avatar
turbo84gn turbo84gn is offline
turbo84gn is on a distinguished road
Question Is this normal?
What would cause this? Is this normal? 87GN, just cruising at speed, the retard and knock will climb, then settle back down, but I notice no change in the motor. Engine runs great. Here is link to video. Have a knock guage too, and it shows the same thing when the scanmaster does, so am thinking it is getting the indication from the computer. If it makes any difference, I can't use TurboLink, the data it reads is all over the place for everything. Says codes are set and dash says not, etc,. Like I said, car runs great.
http://youtu.be/zV0kst71M2g
Old 07-31-2012, 04:48 PM
Royal-T's Avatar
Royal-T Royal-T is offline
Royal-T is on a distinguished road
Default Re: Is this normal?
Nope, not normal..... something is loose and setting off your knock sensor..... exhaust, brackets, etc.... is causing a "false knock"
also whats up with your tach signal?
-aaron
