Missing and running very rich (Was: Help needed)
Hello All,
I am having trouble with my 87 GN. Here is a brief problem & what I have done so far. The car misses while it's running but worse between 1850 to 2000 rpm. When it is missing it is running very rich (enough to leave black soot on the ground) & it's not trowing any codes. Here is what I have done so far, 1 step at a time with no changes to the problem. - changed MAF twice, reset ECM, - checked TPS voltage with no dead spots or drops when it is missing - checked the fuel pressure with no changes when it is missing - checked AF on scanmaster when it's missing & the reading doesn't change - changed IGN module twice & coil pack twice - changed spark plugs wires & spark plugs (all plugs were black from burning too rich) - checked & rechecked all air hoses to make certain there was no leaks I am at a wall. I have no clue what to look/check for next. Does anyone have any suggestions? Thanks for any forthcoming help
Scanmaster,160 degree thermostat,Big Mouth cold air kit,LT1 MAF & Translator,Hooker Super Competition headers & downpipe kit,Walbro GSS340M with Racetronix Hotwire Harness,RJC plenum plate,Turbotweak chip. Best E.T. 1/4 13.861 @ 102.978 mph Last edited by map 87 gn; 05-31-2012 at 08:42 PM. |
Re: Help needed
with it running try unplugging the cam sensor and see if it smooths out.
It would be alot easier to diagnose if you could post a powerlogger file |
Re: Help needed
Thanks for the suggestion..I will try that over the weekend.
Sorry I have no powerlogger just a scanmaster.
Scanmaster,160 degree thermostat,Big Mouth cold air kit,LT1 MAF & Translator,Hooker Super Competition headers & downpipe kit,Walbro GSS340M with Racetronix Hotwire Harness,RJC plenum plate,Turbotweak chip. Best E.T. 1/4 13.861 @ 102.978 mph |
Re: Help needed
are all the dip switches in your translator set correct
Re: Help needed
Yes they are...sorry I forgot to mention that.
Re: Help needed
I sympathize with you my friend. Might wanna check your connections again, I had a similar experience nearly drove me nuts.....hairline crack leaking air around the intercooler under increased rpms. Also had an intermittent coil pack that was somewhat similar too. Sounds like all the sensors are doing the job though...no codes, sorta points to a physical problem. My 2 cents....
Dave Moberg |
Re: Running very rich (Was: Help needed)
Are the symptoms present both in gear and out of gear?
Any differences between in gear and out of gear behavior?
Re: Help needed
I assume that it is pointing the correct direction...
Re: Missing and running very rich (Was: Help needed)
Also, check timing. The crank trigger wheel may have moved on the balancer.
Thanks dmoberg I will recheck the intercooler to see if there is a crack somewhere. I will also check all the connections again. Never hurts to double check.
Thanks Keller. Yes the symptoms are present both in gear & out of gear & there is no changes between both. The MAF is pointing in the right direction. i did try to unplug the MAF & it ran even worse. Good idea for the timing, I will check that out also.
