lifters
hi my name is scott iam new to this but i have an 87 t type and iam having problems with lifter knock i put new lifters in does any one know what can cause this my oil pressure is fine i dont no what could be causing this
Re: lifters
a flat or worn cam lobe..
Re: lifters
thanks phil ill look in to that when i changed the lifters the cam looked fine there was one lifter the 2 cylynder on driverside exhaust valve the bottom of the lifter was smashed in i thought the lifter was defective i was worried it was an a oil problem
Re: lifters
If the lifter is damaged, then the cam is most likely damaged or rounded as well ...
Re: lifters
well i got the cam out of my t type and 5 lobes on the cam are destroyed i checked all cam bearings are fine does any one know what could destroy a cam shaft like that the came is a comp 218 witch i found out is discontinued people i talk to say its my vavle springs i have lt1 valve srings but i dont think so i wonder what cam to replace it with and does any one no if i have to reprogram my chip?
Re: lifters
Could be a number of things ...
Re: lifters
Don't forget to add if its a stock cam that this is a common problem with that lifter and cam lobe. The cams weren't ground right and that lifter doesn't rotate properly and it rounds off the cam lobe. Mine did the same thing. I put a Lunati cam in. It is supposed to have a special grind on this lifter lobe to make sure this doesn't happen again. I'm sure other cams might to but off hand don't know any.
Paul |
