Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Fuel Systems
Old 07-12-2011, 12:22 PM
normster's Avatar
normster normster is offline
normster is on a distinguished road
Default Fuel Pressure
What is the fuel pressure supposed to be in an '87 Grand National with everything still stock?
Old 07-12-2011, 01:28 PM
Post Re: Fuel Pressure
http://www.gnttype.org/maint/quickref.html
~33-34 PSI with the vacuum/boost line removed from the regulator at idle.
Old 07-12-2011, 10:09 PM
normster's Avatar
Default Re: Fuel Pressure
Thanks Keller. Not to seem too dumb, but which one is the regulator?
Old 07-13-2011, 12:41 PM
Lightbulb Re: Fuel Pressure
If you have the stock regulator, it will be a black, somewhat cylindrical object on the driver's front edge of the fuel rail. It will have two bolts holding to the rail, and a drain line coming off the bottom, and a vacuum line on the top. It also will have "BOSCH" in white paint screen printed on the side, along with a part number.
Old 07-13-2011, 06:02 PM
normster's Avatar
Keller
I found the Bosch part you wrote about. Pressure is fine.
