engine rebult by GN/T Performance in 99
Hello I had my engine rebuit by GN/T in FL in 99. I then got sidetracked for several years. They went out of business soon after the rebuild. The engine has less than 30,000 miles on it since the rebuild. My questions are 1. did they have a good reputation with rebuilds, 2. the cam is a GN116T does that mean anything other than the noticable lobe at idle, 3. with the speed pro pistions and rings ARP bolts, 30 over and balance, 30# inj, port matching and a TE 62 am I at a good start for mid to low 11sec or is it a mismatch that will never work? I need the trans rebuilt again and am still using the RED 93 for stock inj and stock turbo that I bought in 95. I want to know if the car is worth putting more money into? Thanks for any suggestions.
Re: engine rebult by GN/T Performance in 99
1. GN/T seemed to be doing some pretty good work. Of course, Dave Schmucker is a little out of touch right now...
2. You would really need some hard specs from a cam card to tell anything. But if it lopes, it may be pretty large. 3. The 30# injectors are really not large enough to supply a TE62 turbo or low 11s. No turbo upgrade at all, really. And barely 12.0s. I would recommend at least 50# injectors, and a better bet would be the new Mototron/Edge 60# injectors, as they are high impedence and would not require ECM modifications. (This is really a question for another area of this board.) Its only worth putting more money into if you want to keep it and not ruin it.
Thanks for the quick response. I feel better about my starting point knowing that they did some good work.
87 WE4 04 GTO |
Mike Gallagher "Master of Indecision" |
