IC fan hitting metal IC shroud?
Hello all. Been tweaking for while and decided to give it a good hard run down a flat straight deserted road, well 4. anyway all readings looked good, O2=757, Knock recall showed 5.2, MAF=239, not WOT, only ran about 12 pds of boost. I did not just hold it to the floor to see what would happen. After making the last run, a scratch/rub is coming from around the IC fan, it seems like it is hitting the metal piece on the IC that surrounds it. Any thoughts about what might have caused this? TIA, Joseph.
Re: IC fan hitting metal IC shroud?
sorry all, false alarm. after further inspection, after kicking myself, i found that the IC hose to the turbo had come down/loose, just alittle to knock the IC out of alignment. Thanks.
