Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Hot Air Cars - 1984 - 1985 Turbo Regals/ GNs
Old 12-03-2008, 12:17 AM
fmster fmster is offline
fmster is on a distinguished road
Default Vacuum can
Hi to all! Where does this vacuum can go and what lines plug into it.
ID:	1270  Click image for larger version
Old 12-04-2008, 08:47 PM
brad_padgett brad_padgett is offline
brad_padgett is on a distinguished road
Default Re: Vacuum can
I know where the cannister goes- Up by the heater blower motor. Bolts on there. Can't find which vacuum lines hook up there yet. I suspect the heating/AC system since it is not listed on the vacuum line tag. Will kep looking is the service manual. Good luck- Brad
85GN, Hk exh., 2 1/2 int. DP(no TB elbow) 42.5 inj., adj FP, Walbro 340 hot wired, adj waste, 87 ECM, F-body rad, dual electric fans, 87 IGN HW, TT chip, Alky. Port & MAT heads, TA33C Turbo., powerlogger, WB O2 , 2800 SV., MT DR, 18 lbs boost.
Old 12-05-2008, 12:06 AM
One vac line goes to the vacume block on top of the throttle body(six hose setup). Left to right closest to the firewall nipple number three. This goes to your tank. I do not know which is in or out of the tank. The other vacume out of the tank controls the heating/ cooling valve behind the heater/a/c controls. This was verified with the help by Jerryl on Turbobuick.com. If you start posting there you will get alot more help faster. I am not here very often. Good luck- Brad
Old 12-05-2008, 12:10 PM
Thanks Brad!
