F-41 Braces location
i bought a set of f 41 braces from ebay, where under the motor do they fit , what about the smaller bars, 1 set said under engine and the other said front support, ad said fom 79 cutlass,smaller set dont seem to fit from the rad support to the fender bolts.any help here
thanx |
Re: F-41 Braces location
the oned under the car go from the radiator support to the engine crossmember.
the ones under the hood go from the radiator support to the fenders. i had to make mine fit alsobut they do go on. also they make ones for behind the rear seat.. looks like 2 "XX"
84 gn / 87 engine .030 109 ballanced, gt51 25#, msd 50# inj, all billet mains, bms rods, ported heads, comp cams .459 lift, champion intake, precision fm, accufb 70mm tb, 340 fp hotwired, northern alum rad, b&m tranny cooler. all on 93 octane... |
thanx for the help,ill try that place,keep info coming,will keep you informed
THANX FOR THE INFO, YOU WERE CORRECT, JUST A LITTLE DIFFERENT TRYING TO PLACE THEM , THERE IS A LEFT AND RIGHT THEY HAVE OFF SET BENDING, TRICKY GETTING THE BOLTS IN THE MOUNT UNDER ENGINE...BUT ALL DONE THANX AGAIN SCOTT
Tom |
