Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Turbo TRader > Parts FOR SALE
Old 01-28-2009, 11:48 AM
Grand Nash Grand Nash is offline
Grand Nash is on a distinguished road
Default Lots of parts for sale: exterior, interior, engine, trans, suspension.
Open to offers on most parts, unless a price is listed, I am building a hybrid selling off some stuff laying around to help with the cost of parts I still need for the project car.
See pics of most parts http://s229.photobucket.com/albums/e...ale/?start=all
If you do not see pictures of a part for are interested in please let me know and I will take some for you. -Ed
Exterior:
Rear bumper impact strip (all black) 8 out of 10 very nice.
GN rear bumper with rust in inside, paint bubbles front rust on outside (pick up only).
Rear bumper support, steel (pick up only)
Front bumper support, steel (pick up only)
Stock fuel door/license plate holder
Trunk latch, with hardware
(2) GN emblems used,
Antenna guide and nut for fender
Quarter panel vents
License plate nylon nuts (new)
Interior:
Door escution trim, chrome missing on end near pull strap
Gray seat belt trim
Cruise control, black control box for under dash (2 each)
Passenger side window switch
Vss buffer, inferred eye missing
Door lock pull up knob
NOS Brake switch for brake lights (NOT POWERMASTER)
Used IGN switch
Gray B pillar trim (pair)
Nice used set of door glass dew wipes the interior ones that attatch to the door panel.
Engine:
Turbo shield cut for 3” downpipe, new triple chrome plating $150
Mint triple chrome plated oil fill tube with cap $75
Exhaust elbow, mildly ported
Complete cam sensor, used working cond
6 Stock injectors
Stock fuel press reg
Fuel rail fuel pressure guage
Stock Cat converter modified to accept 3" DP
Rear coil pack/ign module support bracket
AC lines, driver condition
Good original Ac comp
2” heavy duty intercooler to turbo couplink (2 available) & (1) 2” T clamp
AC/Heater relay silver one under hood
2.5” exhaust clamp
2.25” exhaust band clamp brand new
AC line flex tubing
Starter heat shield
Good 2 bar map sensor
3” cutout pipe block off plate with wing nuts and tool
Trans cooler line, short rad side
EGR valve good used
Stock vacuum pod with gasket & bolts
IAC gasket
Stock oil filter adapter nut
T-Stat housing
Good used crank sensor with mount
Stock stat new
Delco 02 sensor used good low miles
Oil pump pickup
Stock oil cooler lines
86/87 Throttle body - no linkage arm, spring kit, TPS, or IAC Its a bare throttle body with shaft and throttle blade.
Good used timing cover with oil pump (missing timing tab & mech fuel pump block off plate)
Good used water pump, new gasket included
Good used power steering pump (no pulley)
Plastic EGR cover
Turbo oil feed line
Stock plastic vacume pod (no gasket or bolts)
Fuel rail feed & return lines (frame to fuel rail) $75 shipped.
Suspension:
2 steel brake drums, painted with silver vht 1500 deg paint
Stock rear swaybar with hardware
Stock lower control arms,
Trans parts:
Misc trans pan bolts
Good used D5 converter $75
2 torque converter inspection cover (one missing a bolt tab, other has cooling holes drilled)
19k mile trans pan with bolts
Trans BQ 200r4
I picked up a motor Sunday 1/18/09 and it came with a transmission that I do not have a need for, I already have a 200r4 built for my project so this trans has to go.
Working BQ 200r4 - No converter $250 obo, with D5 converter $300 obo
Pick up only or I can deliver it for a gas fee up to 50 miles from zip 19014
+ shipping on all parts to 48 states, unless pick only is noted
MAGNA MagnaBuick.Com
87 GRAND NATIONAL:
Click Here For GN Pics
Old 02-16-2009, 12:38 AM
jessecool's Avatar
jessecool jessecool is offline
jessecool is on a distinguished road
Exclamation Re: Lots of parts for sale: exterior, interior, engine, trans, suspension.
I need lots of parts,i am converting a regal limited........if you can give some prices for the following parts if you have them.....front and rear seats,gas tank with fuel pump/sending unit,front marker lights,rear spoiler,bumper fillers,console with shifter,steering wheel.............thanx
Old 02-16-2009, 10:44 AM
Default Re: Lots of parts for sale: exterior, interior, engine, trans, suspension.
I do not have anything you need.
87 GRAND NATIONAL:
Old 02-18-2009, 07:36 PM
NOIZEOF86 NOIZEOF86 is offline
NOIZEOF86 is on a distinguished road
do you have the factory air filter housing?
Old 02-18-2009, 07:43 PM
I only have what is in the add
87 GRAND NATIONAL:
Old 03-17-2009, 03:02 PM
Buzzp Buzzp is offline
Buzzp is on a distinguished road
Need:
Rear coil pack/ign module support bracket. Does this come with the support bar also?? Offering $20 + shipping?? Let me know. Thanks.
Old 03-17-2009, 03:15 PM
already sold. sorry...
87 GRAND NATIONAL:
Old 04-12-2009, 04:10 PM
kane123 kane123 is offline
kane123 is on a distinguished road
Where are you located? I'm intrsted in the tranny/torque converter combo. What does BQ stand for?
Old 04-12-2009, 06:57 PM
PhillyTurboSix's Avatar
PhillyTurboSix PhillyTurboSix is offline
cRaCk wHoRe
PhillyTurboSix is on a distinguished road
Send a message via AIM to PhillyTurboSix
I don't know how often Ed comes on this site but he is located near the Philadelphia International Airport. PHL. BQ is the valve body in the trans. BRF came in the GN's so he's just letting everyone know that this trans is most likely out of a olds or Monte SS. Not that it's really needed but some people like to have the BRF valve body in there.
86 Buick Grand National CF5 car. Stock.
87 Buick Grand National CC1 car. All the usual mods.
89 Turbo Trans AM #396
Pennsylvania State Representative for MAGNA
Join Today!
http://www.magnabuick.com/
Old 04-13-2009, 12:59 AM
That is incorrect. The BQF code transmissions are from Turbo Regals, just not the 86/87 ones. See http://web.archive.org/web/200701281.../thm2004r.html The exact valve body code will tell the whole story.
