MAFT+, 3.5" MAF install and stalling
I just installed my MAFT+ and a 3.5" MAF I bought from someone on the board in my 86 GN.
The car will start up and run for about a second then stall out. I have all of the settings set at defaults or whatever just replaces the stock MAF. I also installed the spark control part of the harness hoping this was the problem, its not. Any ideas? Thanks in advance |
Re: MAFT+, 3.5" MAF install and stalling
Did you reset the ECM?
I'm running the MAFT PRO, so I'm not too familiar with the Trans +. Go here: www.fullthrottletech.com Best place for info/advice on the T+ HTH
I am an AlkyHolic. I am Smasher Devourer of Rice and Wanna Bees. I am Regal, bearer of turbo. Fear me. |
who's chip are you running?
what are the dip switches set to? |
I reset the ECM.
As far as chip...no idea. It is modified, but by who...no idea. I inherited the car as it sits. The dip switches are set On, On, On, Off. All other dials are set to 0. |
did you install the 2 wires that go to the coil/module??
if not make sure you jump them back together **edit just re read first post.. is the arrow on the maf facing the right direction? |
will it start and run with the stock maf back on??
The arrow is pointing towards the turbo, which would put the connector facing the radiator if its on top...correct?
Haven't tried the stock MAF again. I have moved on to some other stuff i wanted to do with it today waiting for replies. Should I try the stock MAF again? |
I'm also posting over on Fullthrottle's website.
This is what I have learned. With the 3.5" maf plumbed in, the MAFT+ unplugged, and the EST jumper in the vehicle will start up. As soon as I plug the MAFT+ back in it dies almost immediately. |
what version is your box? and how many adapters are you using??
I believe 5.21
Adaptors? If i'm thinking the same thing as you, just one that goes between the MAFT+ connector and the MAF connector. |
