Old 09-30-2015, 03:40 PM
Default Ticking Noise Diagnosis
Recently, when driving my Buick I hear a loud ticking noise that gets faster as the accelerator is pressed to the floor. The car has plenty of power and no codes present on scan master. This ticking noise is sporadic which might last 10 minutes then goes away on its own. I recently poured some "Marvelous Magic Oil" into the car when I heard the ticking sound. It was about 30 seconds while the car was running the ticking noise stopped instantly and didn't hear the ticking sound for 4 days. Last night, the ticking sound started again and last 5 minutes while driving but then went away. I'm leaning towards a bad lifter but not 100% sure so thought I would ask the Buick community for help. Any thoughts on the ticking sound???
Furthermore, if this is a lifter issue can these be changed out without removing the heads???? The heads on my car are the stock heads. I just can't remember if there would be any accesses to these lifters.
Jamie C.
Old 10-06-2015, 02:51 PM
Default Re: Ticking Noise Diagnosis
I would point to a sticky lifter ... especially since it seemed to change behavior after you poured in the MM oil.
However, as part of due diligence, I'd check:
  • Crank sensor clearance ... be sure it's not loose or the rubber elastomer in the balancer isn't shot (and causing it to hit the interrupter ring)
  • Check torque converter bolts to make sure you aren't hearing the flex plate
  • Check for clearance in the valve cover to rocker area ... I once had a mysterious tick that came and went at random and finally traced it down to a rocker juuuuust kissing the inside of the valve cover. (I had 1.65 rockers and spacers)
Old 10-06-2015, 06:06 PM
Thanks Ken I will check those things out that you mentioned. If this does turn out to be a "sticking valve" is there a way to replace them with a special tool with the heads still on the car or does this require pulling both heads and intake to get to them???? I'd hate to have to tear half the motor apart to replace them but if its the only way then I guess I got no choice or just rebuild the whole darn motor. Thank you for the information you provided.
Jamie C.
Old 10-06-2015, 06:14 PM
If it's a lifter (not a valve) ... it's a PITA, but you can pull the intake manifold and get to the lifters (after removing the rockers and pushrods).
If it's a valve, you have a lot more problems and you're looking at just pulling the motor and doing a refresh (easier than doing it in the car).
IF it's a camshaft, that can be done with the engine in the car, but it's almost easier to do it with the motor out.
Old 10-08-2015, 04:16 AM
Thanks Ken. Sounds like no matter which way I go with this it sounds like its going to be a pain in the ass regardless not to mention the money to fix it. Huge Sigh!
