cam sensor noise
sent to have smoged.came back rough idle cam sensor noise.if i push back noise stops.any help
Re: cam sensor noise
What do you mean by "push back"?
screwdriver on front.push back
I goes where the distributor goes in a normally aspirated engine, of course. Chances are either:
- The gear is worn (slim chance) - Your timing chain is going (better chance) - Your sensor reluctor ring is damaged (high chance) This may be all it needs: http://www.rjcracing.com/RJC_Buick_P...camsensor.html Hard to tell without being there. Pull the two screws on the top of the cap and see if there is any play in it.
little movement back forth and turning.think cap was broken came apart when taken off.broke sensor green wire
You can get just the sensor cap.
http://www.partsamerica.com/ProductD...pe=985&PTSet=A Or one from Casper's that offers faster starting and an LED showing when it is working properly. https://www.casperselectronics.com/M...Category_Code=
hanks will get caspers.put on cap from another car same noise push back stops.exhaust is smother sound engine rougher than be 4 smog.turbo line was also moved.no idea y.would cam sensor off adjustment cause engine to be rough.trying to get ready 4 mods.te-60 oo9s th down pipe hot wire chip ect.car has 100,000 miles.is that 2 many 4 mods.thank u
Yes, it may be out of adjustment. There is a process on our web pages for setting the sensor.
Doing a lot of mods on a car with a lot of miles can be risky...
