Old 11-11-2008, 02:35 PM
fmster fmster is offline
fmster is on a distinguished road
Default Need Help
Hi to all! What are these wires and where do the go? And on the coil pack what plugs there?
Old 11-11-2008, 03:31 PM
06_vrscr 06_vrscr is offline
not an owner
06_vrscr is on a distinguished road
Default Re: Need Help
those look like ground wires to me. are they all black wires. there is a plug that comes out of the harness at the back of the engine that plugs into the coil pack and it has a small bolt through it to bolt it to the coil pack
Old 11-11-2008, 07:28 PM
Lightbulb Re: Need Help
Those do look like grounds. Believe they go on the back of one of the heads. The passenger's has a ground strap, so perhaps its the other side. Never had my motor out or heads off...
The coil (any 84-87 car) had only six leads from the ignition module. The module has a harness that slides into one end and is held in with a 1/4" encapsulated screw/bolt, and then has the leads to the coil.
The picture appears to be an 84/85 car or prior because the fan belt is not wide and ribbed. So (at least stock) it would have the earlier module and coil near the front driver's side. It can be converter to 86/87 type if that is the case.
Old 11-11-2008, 09:34 PM
correct those are ground wires
Old 11-11-2008, 11:23 PM
Thanks to all,I got the ground wires in there place.Now what plugs in here?
ID:	1234  Click image for larger version
Old 11-11-2008, 11:34 PM
not an owner
to me it looks like the cam sensor plug, i am going off of an 87 year model which is a little different but thats what it should be it should be located on the front of the engine above the water pump it will be a little black looking cap about the size of the top of a coke can with a connector that will plug into that plug.
here is a pic of the whole assembly just the top black cap should be what your looking for
Old 11-12-2008, 12:51 AM
That plug is coming from the coil pack connector.
Old 11-12-2008, 12:55 AM
not an owner
the cam sensor feeds a signal to the ignition module which is the part under the coil pack,
the picture I posted is what you need to be looking for to plug into the connector that is in your picture
Old 11-12-2008, 01:02 AM
I have That connected already.The cam sensor to the crank position sensor.
It's an 84.
Old 11-12-2008, 01:08 AM
Exclamation Re: Need Help
Ignition module connector, no?
I just pointed out that the coil pack has no harness connector. It does have six tabs on its bottom, which mate with the wires on the top of the ignition module.
