Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Body/Trim/Detailing Tips > Detailing Secrets
Old 03-21-2008, 11:04 AM
drewt1047 drewt1047 is offline
drewt1047 is on a distinguished road
Default cleaning engine bay?
What is the best way to clean the engine bay? Can you use Gumout like any other car?
How about cleaning the fuel injectors?
What is a good cleaner to use to clean out the intercooler?
Old 03-21-2008, 10:38 PM
Lightbulb Re: cleaning engine bay?
I'd suggest Simple Green for the engine bay. Perhaps the IC, to. Though maybe Gumout would be better there. Be careful about getting water/fluids in the MAF or any electrical connections.
Techron (not cleaner "with" techron) is good for injector cleaning in-tank. Removal and use of a machine is the best way.
Old 03-21-2008, 11:15 PM
Default Re: cleaning engine bay?
Thanks I am trying to follow the spring cleaning list to make sure my car runs right.
Old 03-31-2008, 11:36 PM
JST A 6 JST A 6 is offline
JST A 6 is on a distinguished road
I used Simple Green for the intercooler both inside and out, then since a more TR-experienced friend of mine had told me to use gasoline to flush it out I did that too just to make sure I got it clean and the gas came out clean when I dumped it so I think the Simple Green did a pretty good job. I then rinsed it with plain water and used my shop vac to blow the inside of it dry for 1/2 hour or so--my vac has a large diameter hose so it fit into the intercooler/up pipe boot perfectly for this.
Mike
1987 GRAND NATIONAL
Many changes planned but for now it has:
  • TE44 turbo
  • MSD 50 lb. injectors
  • Turbo Tweak 93 octane street chip
  • RJC Power Plate
  • VDO boost gauge in pillar
  • adjustable FP regulator
  • Hotwired fuel pump
  • Fuel pressure gauge
  • 8" K&N cone filter
  • ESP coil pack
  • 160° thermostat
  • test pipe w/ cutout
  • Flowmaster exhaust
  • Scanmaster 2.1
Old 04-01-2008, 12:10 AM
i removed my engine and trans and used "oven cleaner" on the frame etc... came out spotless, then i painted it
Old 04-03-2008, 12:07 AM
Would you suggest using a power washer to spray the engine bay?
Old 04-05-2008, 01:12 AM
I'm not going to say it's a bad idea, but like Scott said you gotta watch where the water goes, and also I wouldn't do it with the engine hot. When I did mine a couple of weeks ago I covered my breathers, air filter, and coil pack but didn't think to cover the alternator and now I have a new one to install due to a squeaky bearing on the one that got wet.
Mike
1987 GRAND NATIONAL
  • TE44 turbo
  • RJC Power Plate
  • ESP coil pack
  • 160° thermostat
  • Scanmaster 2.1
Old 04-13-2008, 04:08 PM
BoostedEvIL's Avatar
BoostedEvIL BoostedEvIL is offline
The Rookie
BoostedEvIL is on a distinguished road
Oven Cleaner! Thats an awesome idea Phil. Would you say that its more "potent" than engine cleaner? Did you use a steel brush on the frame, or did the oven clear eat away the paint? Did you use paint on the frame, or that Por-15 stuff? I'm gonna try this out.
87 GN,Roller cam, Accufab AFPR, RJC power plate, LS1 MAF,roller rockers, ported stock heads, 60lbs injectors, Turbotweak chip, TCI TC (3200), TE-60 turbo; TinMan CAI PTS Extreme built trans. Aluminum drive shaft
Old 04-13-2008, 08:36 PM
413turbo's Avatar
413turbo 413turbo is offline
413turbo is on a distinguished road
Send a message via Yahoo to 413turbo
Mike
1987 GRAND NATIONAL
  • TE44 turbo
  • RJC Power Plate
  • ESP coil pack
  • 160° thermostat
  • Scanmaster 2.1
i feel like a dumb**s, but after i hosed my engine last week, i went and had new bearings pressed on my alternator, because it was sweaking. now i removed the belt first, and turned everything the alternator sweaked.. but it ended up being the belt.. i'm embarassed, but new bearing are cheap insurance- so all isn't lost.
darren
Old 04-13-2008, 09:04 PM
i used the oven cleaner and a paint scraper,rinsed with water hose and just some cheap gloss black paint when i was done
