cam sensor voltage
ok well i just replaced all my bent push rods. and moved my cam to the proper location. it was 180 degrees out of phase...i feel like a idiot that is for sure. i got all that set and back together, however now when i was trying to set my cam sensor up. where the sensor was usally 7.5 volts it is reading like almost 12 volts, and then when i rotate it the window where it would drop to 0 it drops down lower around 5-7 volts. Did i mess something up. i did this with a bunch of sensor unplugged because it was easier to get to before i completely assembled the front of the engine, could that have anything to do with it? is my cam sensor taking a **** on me?
BTW thanks all for the help you provided and all the helpful info you guys provided to me. hopefully after this there will be no more problems |
Re: cam sensor voltage
Having all the other stuff disconnected is probably making that happen.
You are checking the right wires, aren't you?
middle blue wire, on the harness side with key on engine off..
