Old 06-14-2006, 10:42 AM
AbeWhat AbeWhat is offline
87 GN
AbeWhat is on a distinguished road
Default Wideband O2
Does anyone know where I could get a wideband O2 sensor? Will the scanmaster just read from the new sensor without any trouble? Thanks -Abe
Old 06-14-2006, 01:31 PM
Lightbulb Re: Wideband O2
See some previous discussion at http://www.gnttype.org/forums/showthread.php?t=1136
There are many different brands and sources. Many brands are mentioned in the article. Full Throttel Speed carries several. Because they are wide band (0-5v) they really aren't designed to work in place of the narrow band OEM sensor (0-1v). However, some can be used in this fashion as well via their attached electronics. They are usually used more as a measurement and data logging tool.
Old 06-14-2006, 03:35 PM
87 GN
Default Re: Wideband O2
Thanks for the info.
So would it be worth the money to get one without having a data logger recording everything that's going on?
-Abe
Old 06-14-2006, 05:10 PM
With some systems, you can integrate a logger into the system pretty easily. Or at least a gauge for the sensor. See http://www.fullthrottlespeed.com/ite...~0~Tp~~Bc~.htm
None of this comes dirt cheap. But its a lot cheaper than it had been.
Old 06-15-2006, 08:30 AM
JHensberry JHensberry is offline
JHensberry is on a distinguished road
IMO, the wideband could be a good thing. It will allow you to get closer to "dead nuts on" in tuning, but the price, extra bung, etc, you can get a car pretty well tuned just by the scanmaster and turbolink numbers.
You could spend the money elsewhere and build up to the wideband in the future, if you wish.
Old 06-15-2006, 10:03 AM
Some of the widebands also emulate a narrow band output, so you can use them in place of a switching O2.
Ours are located in before the turbo, which is REALLY tough on the WB sensors (too much EGT).
I've been using a new device (in a dyno cell) that some guys locally designed and bulit:
http://www.prologger.com/vital_statistics.asp
It has a boost controller, triggered outputs, a tach, and internally records up several data logs. I haven't tried the boost controller portion (again, this is being used on N/A motors on the dyno), but it looks pretty sweet.
