Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Transmission / Torque Converter Tech
Old 05-03-2009, 03:07 PM
KV48's Avatar
KV48 KV48 is offline
KV48 is on a distinguished road
Default shifting
is it normal like after the car has been running a while for it to shift really quick like when i take off it runs up normal in first then upshifts to 2nd then imedietly to 3rd lugging the motor and this is under light acceleration
Old 05-03-2009, 03:52 PM
Default Re: shifting
http://www.gnttype.org/techarea/tran...n/tvcable.html
Old 05-03-2009, 05:27 PM
Question Re: shifting
Your TCC solenoid might be stuck closed as well. This can happen over time.
Does the car feel like it wants to die when slowing down to stop?
Old 05-03-2009, 06:57 PM
KV48's Avatar
not really it will idle pretty normal after i slow down with it still in drive like at a red light it is all good but when i take off (normal acceleration) it will go good through first then go to second then right to third lugging the motor so when i try to go a little faster it just takes for ever to get up to speed cause its lugging so bad
Old 05-03-2009, 11:27 PM
Exclamation Re: shifting
See Phil's comment and link.
Also, check the tag on the passenger's side of the trans. A TR trans (86/87) will have BRF on it. If yours does not, that may be part of the reason for your issues as well.
Old 05-04-2009, 12:47 AM
Craig87GN's Avatar
Craig87GN Craig87GN is offline
Craig87GN is on a distinguished road
My car has recently started doing this. I initially adjusted the tvcable, but it continues. What are your suggestions?
Craig
1987 Buick Grand National, 48000 mile original, no mods yet
2004 Pontiac GTO (wifes car)
2000 Chevy Silverado, 250000 problem free original
Old 05-14-2009, 07:52 PM
Flatire Flatire is offline
Flatire is on a distinguished road
I'm here looking for info.
I have a 69 Skylark, just put in 2004r I bought rebuilt from a guy at the track. Does the same as yours, 1 then 2 then 3,4 and lug.
Bowtie OD said it may be someone had installed a check ball in the lock-up solenoid actuator. I pulled it out, no check ball. Then i pulled the valve body for inspection and cleaning. put it back in same thing.
I spoke to Jerry at TCI, he was very helpful. In the end he suggested i buy one of his VB rebuild kits $80.00. I don't know, but i will soon.
Old 05-14-2009, 08:20 PM
Really should have started a new thread, Flatire...
Do you have any idea what the trans and valve body are out of? Are you trying to set up for lockup? The pump is where that needs to be set.
Really would be best to stay away from the "big names" (i.e. TCI, etc.) when it comes to the 200-4R and stick to the TR crowd with them. They know the most and make all the innovations for them happen.
Old 05-14-2009, 08:25 PM
It's an early trans from an Olds, 81 or 82.
I do have a 2200 lock-up converter, but no power wired yet,
one thing at a time.
Old 06-07-2009, 02:31 PM
KV48's Avatar
so a shift kit from B&m would not be good for the transmission and the car use to chirp and shift hard but like i said now its sluggish
