kenne bell ram air
hello all i just got a used kenne bell ram air kit my problem is i think im missing a lid that goes on the canister around the rubber end of the filter also im not sure where to mount the canister. anyone have this setup that can tell me how and where to mount it thanks for any info.
Re: kenne bell ram air
I'm not sure the cannister 'mounts' so much as it just sits atop the charcoal cannister. I don't believe there is a 'back' to it; I think the filter just seals against it and fills the opening.
Haven't heard that the cannister was restrictive or not. I'd try it both ways and judge the results.
There is no lid. As Keller says, the air filter closes up the large opening. As I recall, a screw is normally screwed into center of the closed end and into the center of the filter to keep the cannister attached to the filter. The other round opening in the filter is where the hose from the air damn is hose-clamped on.
Like Ryan says, ditch the cannister. Lots of threads on the other sites about it being too restrictive. I can tell you when I ditched my cannister, I could really hear the air being sucked in at idle and the "horsey sound" when getting off the pedal.
IL KIM 85 GN w/86 motor, TRW pistons, Weber 206 billet roller cam, EGR welded, o/sized valves, 130psi springs, roller rockers, 3000 conv, adj w/gate, FPR, custom rad, KB ram air, ported, KB headers, Walbro 340M/hotwire, 60lb Hi Z, CPT66bb |
thanks for the responses if i loose the canister then do i use the air dam and hose and where should i put it thanks again
I would place the cannister onto the filter, and use the location of the cannister to route the hose to it as if the cannister was still there. Then remove the cannister.
thanks for the help this site is very helpful
