Upgrading to the powered antenna possible?
I have an 87 GN that came with the standard antenna. Is it possible to upgrade this tot he powered antenna that raises up and down? If so is any additional hardware required?
Re: Upgrading to the powered antenna possible?
I'm sure you can do it.
If you are going all factory, I think that there is a brace required on a GM OEM antenna, inside the fender. This helps keep it from rattling around. As for wiring, there might already be a loose pigtail connection flopping around where the antenna is. I'm not sure if it's connected at the radio side. Good luck, ElectraJim |
