Engine, Trans, Brake, Exterior, Interior, & Stero Parts
Engine Parts:
Kirbans reproduction PVC & Map sensor metal vac lines for the vac pod $20 new in the bag. DRIVERS SIDE INTERCOOLER BRACKET $20 THERMOSTAT HOUSEING, OK SHAPE $10 NEW 195 DEGREE THERMOSTAT $5 GOOD USED LOWER RAD HOSE $5 Refinished - STOCK AIR BOX (COMPLETE W/K&N AIR FILTER) $55 AC DRYER CANISTOR, NEW $MAKE OFFER CAM SENSOR (APROX 85,000 MILES) W/CAP $65 CAM SENSOR DRIVE (MAKES NOISE, NEEDS SHIMS) NO CAP $40 OIL PUMP GASKETS $2 EACH WORKING EGR VALVE (NON AC DELCO) $ MAKE OFFER LOW MILAGE - KNOWN GOOD EGR SILONIDE $45 NEW IN BAG, AC DELCO 87' RUBBER OIL PAN GASKET $25 HEAVY DUTY INTERCOOLER TO TURBO COMPRESSOR HOSE NEW 10 MILES ON IT WENT TO BIG NECK INTERCOOLER $10 Stock Turbo Oil feed line $5 Transmission Parts: NICE STOCK 200 R4 TRANS PAN PILOT HOLE DRILLED FOR ATR'S DRAIN PLUG $15 Brakes: EVERYTHING NEEDED TO CONVERT YOUR TURBO REGAL TO VACUME BRAKES. CONVERSION KIT COMES WITH: VACUUM BOOSTER W/ CHECK VALVE MASTER CYLINDER ASSEMBLY MASTER CYLINDER RESERVOIR W/LID ALL HARDWARE INCLUDED BRAKE PEDAL ASSEMBLY INSTRUCTIONS 1 KIT AVAILABLE $110 Exterior Parts: CHROME WHEEL WELL MOULDING - DRIVER SIDE FRONT $15 CHROME WHEEL WELL MOULDING - PASSENGER SIDE FRONT $15 CHROME WHEEL WELL MOULDING - PASSENGER SIDE FRONT $15 OPERA COACH LIGHTS (PAIR) $25 FRONT FENDER CORNERING LIGHTS (PAIR) $45 PAIR OF DOOR VENTS $10 2 REGAL EMBLEMS GOOD FOR DAILY DRIVER $5 EACH 1 BUICK TRUNK EMBLEM GOOD FOR DAILY DRIVER $25 GN TRUNK DECK LATCH ASSEMBLY $15 GN TRUNK DECK LIGHT ASSEMBLY $10 NICE 87 HEATER CONTROL UNIT $20 LOWER BODY BUSHINGS (FEW ON HAND IN GREAT SHAPE) $ 5 EACH Interior Parts: 87 T STEERING WHEEL CENTER MEDALION NEAR MINT $8 Brown Horn Pad $15 BROWN TRIM RING THAT SCREWS TO THE BACK OF THE STEERING WHEEL MINT $15 CAN BE PAINTED TO MATCH OTHER COLORS. 1 PINT OF TAN INTERIOR (SEM PLASTIC PAINT) MATCHS GREAT $25 OBO GREAT FOR PAINTING GUAGE PODS! Pair of Tan Pull Straps $20 very clean Pair of cloth Tan quarter panel trim inserts $10 Stero Equipment: Kenwood KRC-609 Exelon Cassette radio Removable / flipable face plate. CD changer controls. Works great no problems Mint condition - looks/works like brand new $125 10 Disk Kenwood CD Changer - Works / plays Cd's but has an occasional skip when you hit certain bumps. Shoud be able to be fixed. $75 obo Pics are available upon request.......................Thanks for looking. |
Re: Engine, Trans, Brake, Exterior, Interior, & Stero Parts
Cam sensor w/cap - Sold
Heater Control unit - Sold TTT |
Ttt..........
I need the ring that goes around the horn.. how much?
Ed |
Ttt.................
need a 86-87 brf tranny... got one ? how much ? where are you located
thanks Rusty |
To The Top
To The Top
To The Top
