WTB Clean T-type or GN in midwest
Just like the title says. I am looking for a clean rust free, well maintained T-type or GN in the midwest. I am in Joilet, IL which is 30 minutes west of Chicago. Let me know what you have.....looking to spend upwards of $9000. Email address is berg1626@aol.com.
Re: WTB Clean T-type or GN in midwest
I have two Turbo-t s forsale in OKC, OK.
One only has 34k orginal miles Navy Blue/blue all stock except exhaust,shocks,radio/cd player(I still have all original parts) and GNX dash. $16,500 The other is a 1987 Buick Turbo -T that I purchased from the original owner. I have all the original paper work /brochures/window sticker etc... the car faxed with 92k miles on it but it had a complete rebuild/ build up about 5000 miles ago. Mods: A lot of things under the hood have been chromed or ceramic coated; including the headers and cross over pipe, valve covers, down pipe, chrome t-shield and pipes etc. 3.8 block .030 over, balanced block girdle Steel main caps ARP fasteners & cylinder head studs thermal coated TRW pistons lunati 200/200 cam parkerized TRW springs ported heads w/larger valves ported matched intake PTE 60 turbo with turbo saver 55lb injectors ceramic coated factory headers Terry Houston down pipe ceramic coated test pipe to dual flow master w/ dump Volt booster High performance in tank fuel pump with hot wire Mark Jackson stretched notched intercooler Conley cold air package w/14 inch K& N filter Trans: factory 2004r with high performance rebuild , Art Carr 3200 stall 9" lock-up converter and Stage Right trans brake w/ BM trans cooler installed an additional drain plug for servicing the trans.) Drive shaft loop rear end has girdle w/ about 40,000 miles on it w/drain plug. KB Frame braces behind seat and up front Replaced all GNX frame bushings that were missing All stainless steel brake lines New brakes w/ new Kirbin Accumulator New tires Morso Three way adjustable race shocks Air bag in right rear spring pinion snubber Interior: Grey Custom instrument cluster by Charge Air Systems / White Auto Meter phantom gauges GNX style w/ red back light Stock radio Panasonic speakers A/C was converted to R134A- 2003 Exterior Paint is good- repainted Interior is in excellent condition. Excellent head liner and sun visors. appraisal No rust & No undercoating Price reduced to $14,500 Both are excellent examples I can email pics or come buy and take a look. I live in SW OKC just off I-44. Bwlong@cox.net |
