Boost gauge wont work
HELLO guys have a 87 limited turbo....it has lights for tach and boost gauge ..tach works fine but boost gauge stays at zero...what do you guys think it can be....by the way the turbo is working fine..thanks in advance..
Re: Boost gauge wont work
just sharing the newest horse in my stable 87 buick regal LIMITED TURBO....feel the power wow...
Check under the drivers' front area of the engine compartment. Near #1 cylinder and roughly behind the A/C compressor there should be two connectors: black and green. Both should be empty, and NOT plugged into one another.
Is that the way they are?
If the boost gauge isn't working, first check to see the MAP on the passenger side inner fender is plugged in and the vacuum line to it is connected properly.
If that checks out, then it's pretty common for these instrument panels to develop problems with the traces and/or the driver for the display. Casper's can fix it for you.
empty thanks....
i have another question...on passenger side where rubber line runs off turbo into a little plastic box attached to the first bolt topside valve cover with two wires[plug] and suppose to be two nipples ....one nipple is broken off...the line from turbo is to the one not broken..the one broken is open not capped off should there be something attached at this point...maybe a T fitting connecting the two lines i hooked up between MAP and line off throttle body...im just asking..is this some kinda boost referance port??...thanks in advance
As long as the port is open and not blocked, it is fine.
so no further action needed here? Last edited by smallblock413; 08-14-2011 at 10:31 PM. |
That is it. Fine as it is.
