wiring to/for fuel pump question stumped need help
Hi,
its w/ one of the wires at the rear of tank, 3 pin female connector for fuel pump/sender its tan w/ white tracer- oil sending unit wire? mine has been removed from connector (still in harness coroded) and replaced w/ a wire that runs to positive side of external bosch canister pump, (which Im removing, an putting pump back in tank)... the other wire on positive side runs to the fuel pump relay... looks to be a faded yellow wire?. Could I tie these two together? an run that way? wiring diagram I have does NOT show a yellow or a tan, there is a gray wire on diagram that the tan/white wire connects some were in haness....... thanks, ray Last edited by gnray76; 02-28-2010 at 01:30 AM. Reason: clean it up |
Re: wiring to/for fuel pump question stumped need help
Ray, The stock setup at the plug in at the fuel tank is ,black wire for ground, a pink wire for the fuel tank level sensor and the tan wire with the white stripe for the fuel pump power... Not sure on the yellow wire... Has there been a hot wire fuel pump relay set up added to your system??? In your wiring diagram the grey wire does come from the oil sender and original fuel pump relay in the engine compartment, down the line it turns into the tan/white wire to the fuel pump... Don't start hooking wires up together until you know their source... Maybe you could get some pics of what you have to help us??? Tom G.
www.tomsttype.com Grand National Diagnostic Manuals |
thanks for the reply, over 60 people looked at this thread on turbobuick an know one replied... so I signed up here, so I thank you again...
I had unplugged the connector from the relay, these wire's are so.. over 20yrs old if you know what I mean..yuk So the bulb turned on above my head... I took a razor and scraped the wire insulation to remove the outer 20yr old discoloration, (it was gray), so chitty and feel dumb cause this wire looks LT. YELLOW....chit happens... I had hooked wires together at tank (before soldering and heatshrinking)... turned key forward and checked power at relay, when I hooked battery up, relay clicked 12v on and then shut off 0v's so I know that was the pump prime. woo hoo what a relief....... |
This site is all about tech, not chat. Feel free to stay awhile. And tell others.
thanks keller!!! and thank you...
