1987 Grand National T-top car 85K miles. CLEAN.
87 G.N 4 Sale. No leak T-top car. This is a rust free, No rips very good car. this car has NEVER been to the track Due to I have a mean 70 10.00 car That is raced. This car is for going anywere short or far as I do. Garage kept. all year round. Got cought in the rain once on the Hot Rod Power Tour. Needless to say I was PISSED. This car is 95% stock except. 3 inch exhaust with no cat. I run a so called test pipe. It can be loud under boost. Never got stopped by the fuz. Adjust wast gate. Drivers motor strap. 43 plugs. Life time plug wires. New coil pac. New belt and hoses. ( I Did keep the orig ones ) Temp and boost gauge in car. Kenny Bell 4inch cold air with a K and N filter. Stock map sensor. Hot tanked the stock inner cooler. Hot 02 sensor. New t.p.s sensor. ICE COLD R12 A/C. New 245/60/15 tires all around. Brakes good New acumalator. Trans just serviced Same with the rearend. New front stock shocks New rear stock shocks' New rear cargo coil springs with air bags. The list goes on and on. I have owned this car for over 6 years and got bit by the Buick bug and enjoyed putting a ton of work in to it. I have a lot of pics of the car if intersted. Thanks for looking Ron...... (CAR IS SOLD THANK YOU)
Reason: SOLD THANK YOU
