Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Engine Electrical/Ignition
Old 03-06-2016, 05:10 PM
CJ87T CJ87T is offline
CJ87T is on a distinguished road
Default Balancer Timing Grooves
Why are there two timing mark grooves in the harmonic balancer on my 87 T? Also the degree indicator tab has a zero mark and there is a visual timing sight tube right next to it. What's the deal? Thanks.
Old 03-09-2016, 07:12 PM
larrym's Avatar
larrym larrym is offline
larrym is on a distinguished road
Default Re: Balancer Timing Grooves
one has been added by some one as a mark for setting the cam sensor.
I did the same to mine when I had the motor out, the first one should be the TDC mark the second should be 25 degrees ATDC
60lb injectors
Gen 2 with Extender Chip
Webber 212/206 roller cam
Turbonetics BB CPT 61
CAS V4 Stretch Intercooler
Alcohol Injection
4 inch MAF pipe with integral sensor
2800 stall
lots of fun with a little 6 banger!
Best ET 11.43
