Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Add-on Electronics and Electrical > Scan Tools
Old 02-19-2008, 12:31 PM
dfirefighter's Avatar
dfirefighter dfirefighter is offline
dfirefighter is on a distinguished road
Default Re: Scanmaster hook up
Is there anyway to upgrade scanmaster 2.0 to 2.1?
red armstrong volt booster and 93 chip, adj. fuel press. reg., walbro pump/hotwire., T. Hust. down pipe, 9" K&N, underdrive pulley, art car shift kit/trans pan, trans. cooler.
Old 02-19-2008, 09:21 PM
there is a chip you can change on the inside.. pretty easy to do it..
Old 02-19-2008, 10:16 PM
Originally Posted by PaCemkr86
there is a chip you can change on the side.. pretty easy to do it..
where can the chip be purchased at and for how much?
Old 02-20-2008, 09:10 AM
i think its like 15 dollars or so..
Old 02-20-2008, 11:18 AM
turbojd's Avatar
turbojd turbojd is offline
turbojd is on a distinguished road
You might wanna try www.fullthrottlespeed.com thats where I got my chip to update my translator, talk to Mike.
87 GN PTE TA49, adj.fpr. 2 1/2" Pypes ex. 3" ATR downpipe 3" hI- flow cat, Race pro muffs. 60/65lb.mototron injectors, LT1 valve springs, heads pocket ported, 3 angle valve job, 3" LT1 maf/translator, 340 walbro/ hot wired. 93 TT chip,9"K&N.
Old 02-20-2008, 11:03 PM
anyway to go from 2.0 to 2.2?
Old 02-28-2008, 01:28 PM
turbodave38's Avatar
Retired
2.2 is an upgrade chip that you'd get along with Powerlogger, so that the Scanmaster can directly interface with Powerlogger.
2.1 is the latest if you're NOT going to hook up to Powerlogger.
TurboDave EWCS(SW) USN Ret
H&N Turbo Racing
Sevierville, TN
Old 02-28-2008, 09:16 PM
well I have a 2.0 scanmaster, and fullthrottle sent me a 2.2 chip upgrade. so do i put the 2.2 chip in my 2.0 scanmaster?
Old 02-29-2008, 08:49 AM
Retired
Default Re: Scanmaster upgrades
There shouldn't be any problem using it.
H&N Turbo Racing
Sevierville, TN
Old 03-03-2008, 12:53 PM
fullthrottle does not offer the update chip from 2.0 to 2.1.
anyone know where i can get this update at?
also i am unable to use the 2.0 with powerlogger. and the 2.0 will not work with the 2.2 chip for powerlogger.
