Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Events > Buick Scene
Old 04-19-2008, 08:23 PM
Default new best for the 87 Limited
on a safe 20 psi pumpgas/alky tune
Devils Own alky kit
PT67/76 turbo
60# injectors and TT chip/ LS1 maf
westcoast converter 10inch lockup
Brian Hofer 2004r
MT 28x9's on stock ttype wheels
http://www.youtube.com/watch?v=BPrqD__R-lg
Old 04-19-2008, 08:51 PM
1986GN 1986GN is offline
1986GN is on a distinguished road
Default Re: new best for the 87 Limited
CONGRATS THAT WAS COOL MAYBE SOME DAY MY TR WILL GO 12 FLAT
1986 GN STOCK
Old 04-19-2008, 08:55 PM
here is a match race later that evening
http://www.youtube.com/watch?v=xKl1TvCqlZ4
Old 04-19-2008, 11:30 PM
IL KIM IL KIM is offline
IL KIM is on a distinguished road
Wow! Awesome Phil! Looked like you caught up to that Bike!
IL KIM 85 GN w/86 motor, TRW pistons, Weber 206 billet roller cam, EGR welded, o/sized valves, 130psi springs, roller rockers, 3000 conv, adj w/gate, FPR, custom rad, KB ram air, ported, KB headers, Walbro 340M/hotwire, 60lb Hi Z, CPT66bb
Old 04-20-2008, 01:12 AM
with some more tunning and tweaking the lauch, we hope to put it in the 10.50's
Old 04-21-2008, 12:58 PM
ryan87gn ryan87gn is offline
ryan87gn is on a distinguished road
Nice runs...
Question...only at 20 psi on alky? Is this just where you had it tuned, thus not running higher boost?
87 GN, GT3255E, SMC Alcohol Injection, Mototron 60# Injectors, XP Fuel Pump, Fuel Enhancer, Kenne Bell Ram Air, 3" DP, LS-1 MAF, 3 1/2" MAF Pipe, TurboTweak Chip
Old 04-21-2008, 01:04 PM
correct, we plan on cranking it up 25-30 psi later..
Old 04-25-2008, 10:11 AM
Phil, this may be a dumb question. I'm just starting to learn on the tuning, so pls bear with me. What numbers will you be watching for as you turn up the boost...what will you be doing if this gets too high/low, if that gets too high/low? Looking for what you're watching for and then how you're reacting. I really want to learn now that I'm getting the tools and getting to drive the car. Thanks.
Old 04-25-2008, 10:17 AM
the 2 main things.. are the a/f ratio and the Knock Retard
i perfer to keep the a/f in the 10.5 to 10.8 range with alky and i tune for ZERO knock retard
Old 04-25-2008, 11:27 AM
Thanks. With knock I know to reduce boost. On the A/F ratio...are you adjusting fueling thru the Translator?
