Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Body/Trim/Detailing Tips > Body Work
Old 06-07-2008, 01:33 PM
T-TopFlyer's Avatar
T-TopFlyer T-TopFlyer is offline
T-TopFlyer is on a distinguished road
Question Power antenna replacement?
I need to repair my power antenna. Is there a special tool or socket to remove the nut on top so I don't mess it up? Any other tips about this would be good to know as well as I've never done one of these before.
Old 06-07-2008, 05:17 PM
Lightbulb Re: Power antenna replacement?
http://www.gnttype.org/techarea/body...eriorpage.html
Two articles on doing this.
Never used a special socket myself, but I'm sure one exists. Ask a local car stereo shop what they use.
Old 06-07-2008, 10:41 PM
IL KIM IL KIM is offline
IL KIM is on a distinguished road
Default Re: Power antenna replacement?
When I worked at Willow Run, GM, the Trimmers had a special socket with notches cut in it to to secure the nut. I actually have a similar earlier version on one. Don't know if anyone sells it though.
IL KIM 85 GN w/86 motor, TRW pistons, Weber 206 billet roller cam, EGR welded, o/sized valves, 130psi springs, roller rockers, 3000 conv, adj w/gate, FPR, custom rad, KB ram air, ported, KB headers, Walbro 340M/hotwire, 60lb Hi Z, CPT66bb
Old 06-07-2008, 11:27 PM
Thumbs up Re: Power antenna replacement?
http://www.lislecorp.com/tool_detail.cfm?detail=451
http://www.amazon.com/s/?ie=UTF8&key...l_5uhg9xcbyn_e
http://www99.shopping.com/xPF-Antenna_Nut_Socket_Set
http://www.matcotools.com/Catalog/to...ype=T&cat=2260
Old 06-08-2008, 12:26 AM
T-TopFlyer's Avatar
Question Re: Power antenna replacement?
Thanks for the advice. Would a flat blade screwdriver with electrical tape on the tip to minimize damage and a hammer to tap it suffice? Other ideas welcome.
Old 06-08-2008, 02:05 PM
T-TopFlyer's Avatar
If anyone else is in the same boat and doesn't want to pay for a socket you'll probably only use once, I just used 2 nickels covered in electrical tape and got it right off no problems/scratches etc
