Old 09-02-2008, 02:27 PM
Thumbs up Analyzing ignition misfires - a picture shows why the Casper's tester works!
I haven't touched my car in over a month, as I'd been a bit upset the last time it was out. The car felt like it had a 'miss', but only at high boost. That had me starting to suspect the fuel pump, since that is where the fuel system would be taxed the most.
Of course, that is where the ignition is taxed the most as well.
So I finally broke out the Casper's tester and had a look at things. This is by far the best way to analyze things. The proof is in the pics. The 5-2 pair is simply not firing. If I turn it down to a low RPM, it does fire...very weakly. At high RPMs it never fired at all. This is a new coil, but an older module. Both GM/Delco parts. Worked fine on the street and at street boost levels, but up at 20+ PSI, would stumble like crazy.
At this time, I don't know which part is the problem: coil or module. However I will check them and change what needs to be changed.
Larger turbo is going on while the car is down as well.
Old 09-02-2008, 10:28 PM
Default Re: Analyzing ignition misfires - a picture shows why the Casper's tester works!
nice.. this should be a sticky
Old 09-09-2008, 11:55 AM
IL KIM IL KIM is offline
IL KIM is on a distinguished road
Found this user document. www.installationinstructions.com/102020.pdf
Now, where and how much are these? Anyone have one they want to rent or let me borrow in the Michigan area?
IL KIM 85 GN w/86 motor, TRW pistons, Weber 206 billet roller cam, EGR welded, o/sized valves, 130psi springs, roller rockers, 3000 conv, adj w/gate, FPR, custom rad, KB ram air, ported, KB headers, Walbro 340M/hotwire, 60lb Hi Z, CPT66bb
Old 09-09-2008, 12:52 PM
ryan87gn ryan87gn is offline
ryan87gn is on a distinguished road
Caspers, $124 + shipping.
I was thinking the same thing for the Akron, OH area.
Old 09-09-2008, 07:04 PM
Ryan! Thanks. I noticed Caspers sells a replacement coil pack for less than the cost of the tool! LOL
Old 09-16-2008, 01:58 PM
Exclamation Re: Analyzing ignition misfires - a picture shows why the Casper's tester works!
Its not always the pack. In my case, only changing both fixed the problem.
Old 10-22-2008, 12:10 PM
Electrajim Electrajim is offline
Electrajim is on a distinguished road
Send a message via AIM to Electrajim Send a message via Yahoo to Electrajim
Keep this in mind if ever opening a ignition module, coil pack setup to prevent failure.
http://www.installationinstructions....ci-failure.pdf
Don't forget that there should be a gasket between them too!
Shocking, isn't it.
ElectraJim
Old 02-22-2010, 02:20 PM
BYT86GN BYT86GN is offline
BYT86GN is on a distinguished road
Scott I bought me one of those coil testers from caspers and for some reason it does not work. I called caspers about this and they said something about that it might not work on aftermarket coils. I also noticed that not all of the bolts line up on the coils. I have to hold the tester in place otherwise it will not make contact with all the coils. Have you had this problem and is the factory coil made by AC Delco. Autozone only has a Duralast brand and Oreilly's carries the AC Delco, Master Pro, and BWD brand. Which one would you recommend. Thanks
Mike
Old 02-22-2010, 03:43 PM
Lightbulb Re: Analyzing ignition misfires - a picture shows why the Casper's tester works!
Sadly, AC Delco has gone to sourcing their coils from China. They are also a slightly different packaging. That can affect the fitment of the tester to the coil.
There are some aftermarket coils that hold to the original packaging and are reliable. One source I would note is Highway Stars / NOS4GN. Their US made coils come with a warranty, have a _very_ reasonable price, and are made in the OEM physical format.
They also offer a very solid module. While also US made and, comes with a *2* year warranty, it does not provide an external tach signal. Many of the aftermarket modules do not. If that is not an issue for you, it is very hard to beat. Note that the external tach signal is necessary to make the Casper's tester work!
Highway Stars / NOS4GN offers all the GM ignition parts as well.
Others have noted the absence of the tach signal on the BWD module in the past.
Old 02-22-2010, 10:02 PM
Thanks for the info Scott. I tried looking for the website for highway stars and I was able to find one but it appears to be a broken link. Do you know if there is another website that sells the highway nosgn?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
