Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Turbo TRader > Parts FOR SALE
Closed Thread
Old 11-11-2008, 07:07 PM
TORQUEMONSTERZ TORQUEMONSTERZ is offline
TORQUEMONSTERZ is on a distinguished road
Default 1984-1987 buick grand national t-type gnx tta ****new & used parts****
15 Years Of Collecting Is Now For Sale!! JUST ABOUT ALL IS FROM 86-87 Turbo Regals & Gn's
PICS ARE AVAILABLE ON ANY ITEM UPON REQUEST!!!
Just A Small List Of Available Parts.
Please CONTACT ME For Other Interests. I PROBABLY HAVE IT!!! 610-329-9192
EXTERIOR
78-87 TURBO HOODS: From $100
78-87 L & R COMPLETE DOORS (CLEAN): From $300
78-87 DECKLIDS: FROM $150
78-87 L & R FENDERS: FROM $150
84-87 CHROME OR BLACK FRONT/REAR BUMPERS: FROM $150
84-87 WHEEL OPENING MOLDINGS (BLACK OR CHROME): $75 EACH
84-87 RH TAILLIGHTS (complete): $65 EACH
84-87 FUEL TANKS:$100
78-87 TRUNK DECKLID LATCH: $20
84-87 L & R WINDSHIELD WIPER ARMS (BLACK): $50
84-87 REAR TAG MOUNT BODY FILLER: $35
84-87 REAR LICENSE PLATE TAG MOUNT: $25
84-87 LH & RH FRONT CHROME BUMPER BEZZEL TRIM: $25 EACH
84-87 RH BUMPER LIGHT (NO CRACKS): $25
84-87 HOOD HINGES AND STRUT BRACKETS: $50
84-87 GN REAR SPOILER WING END & 1/4 EXTENTION: $75
84-87 LH BLACK CORNER MARKER LIGHT GM: $55
84-86 CHROME REGAL/T-TYPE GRILLE & SPRINGS (NICE): $95
84-87 FRONT OR REAR BUMPER ISOLATORS/MOUNT: $40 EACH
84-87 LH BLACK HEAD LIGHT BEZZEL (MINOR HAIRLINE CRACK BEHIND CORNER LIGHT THAT IS BARELY NOTICEABLE): $45
84-87 HI/LOW HORN ASSEMBLY: $25
ENGINE PARTS
86-87 COMPLETE ENGINE HARNESS & ECM: $450
86-87 FUEL INJECTOR HARNESS: $60
86-87 MAGNAFLUXED BARE BLOCKS: FROM $375
86-87 COMPLETE REBUILT SHORTBLOCK: $2500 (NO CORE)
86-87 LOW MILEAGE RADIATORS: $250
86-87 A.C CONDENSORS: $75
86-87 A.C HI/LOW HARD LINE ASSEMBLY: $150
86-87 A.C COMPRESSOR BRACKET (REAR): $25
86-87 A.C COMPRESSOR: $75
86-87 A.C DRYER ACCUMULATOR GM: $35
86-87 A.C ALTERNATOR BRACKET (FRONT FLAT MOUNT): $50
86-87 STOCK INTERCOOLER UP PIPE: $35
86-87 THROTTLE BODY (CABLE) BRACKET: $35
86-87 THROTTLE BODY VACCUM BLOCK GM: $20
86-87 EGR VALVE & MOUNT: $30
86-87 THROTTLE BODY BONNET PLENUM: $50
86-87 EGR SOLENOID: $45
86-87 TURBO WASTEGATE SOLENOID: $30
86-87 CAM SENSOR (70K) GM: $75
84-87 KNOCK SENSOR GM: $20
86-87 CRANK SENSOR AND MOUNT GM: $45
84-87 CRANK SENSOR AND MOUNT GM: $45
86-87 2-PIECE CRANK PULLEY: $45
86-87 BARE LOWER PLENUM INTAKE MANIFOLD GM: $200
86-87 POWER STEERING FEED LINE/HOSE: $20
86-87 POWER STEERING PUMP (60K): $75
86-87 TURBO EXHAUST DOWNPIPE GM: $65
86-87 TURBO OIL FEED LINE "GM": $15
86-87 ALTERNATOR MOUNT BRACKET (REAR): $50
84-87 COMPLETE TIMING COVER AND H/V OIL PUMP ASSEMBLY (70K): $65
86-87 ALUMINUM ACCESSORY MOUNTING BRACKET: $75
86-87 BELT TENSIONER & PULLEY: $75
86-87 "GM" HARMONINC BALANCER DAMPNER: $125
86-87 WATERPUMP PULLEY GM: $35
86-87 20 BOLT OIL PAN GM: $75
86-87 BUICK GN GRAND NATIONAL VALVE COVERS & HARDWARE: $65
86-87 INTERCOOLER SHROUD SCOOP (NICE): $75
86-87 IGNITION MODULE BRACKET (FLAT BASE MOUNT): $35
84-87 ENGINE MOTOR LIFT BRACKET: $20
86-87 FUEL INJECTOR RAIL: $60
86-87 STOCK FUEL INJECTORS (70K): $50
86-87 DIPSTICK TUBE ONLY: $20
86-87 STOCK 237 BOSCH FUEL PRESSURE REGULATOR: $20
86-87 IGNITION COIL PACK (TESTED GOOD): $40
86-87 VACCUM BLOCK & HARD LINES: $40
86-87 THERMOSTAT INTAKE WATER NECK: $20
86-87 LH INTERCOOLER BRACKET: $30
86-87 POWER STEERING RESEVOIR & HOSE: $45
86-87 COOLENT OVERFLOW RESEVOIR TANK & CAP (NICE): $20
86-87 COMPLETE OIL COOLER ASSEMBLY: $100
86-87 IGNITION MODULE GM (TESTED GOOD, but 2 broken bolts): $75
86-87 TURBO EXHAUST HEAT SHIELD NICELY CUT FOR EXTERNAL WASTEGATE: $25
86-87 TURBO HEAT SHIELD (SMALL ONE THAT BOLTS TO MOUNT): $15
86-87 GN CRUISE CONTROL UNIT (WORKS): $75
86-87 GN FUEL FEED & RETURN LINES OEM: $95
86-87 GN COMPLETE AIR BOX CLEANER W/ K&N FILTER, & AIR TEMP SENSOR: $125
86-87 STOCK INTERCOOLER (60K) & ATR FAN SHROUD KIT: $125
84-87 SINGLE OR DUAL MUFFLER CATBACK EXHAUST SYSTEMS: $175
84-87 STAINLESS 2.25" TAIL PIPES: $65
84-87 INTERMEDIATE PIPE: $65
86-87 ALTERNATOR CORES: $35 EACH
86-87 RH MAP/RELAY BRACKET MOUNT: $30
85-87 POWERMASTER BRAKE FLUID RESEVOIRS (NICE): $40
84-87 BLOWER MOTOR AND CAGE: $20
***ORIGINAL BOLTS*** ANY BOLT, FASTENER OR HARDWARE (EXCEPT BALANCER BOLT): $5 EACH
INTERIOR PARTS
86-87 GN FRONT/REAR SEATS (NICE): $750
87 T-TYPE GREY SEAT SET (NICE): $700
86-87 UPPER DOOR PANELS: FROM $200 Set
84-87 LOWER DOOR PANELS: FROM $100 Set
84-87 LEATHER PULL STRAPS (GREY, BLACK, BEIGE): $20 EACH
84-87 BLUE INTERIOR TRIM: FROM $5+
84-87 GREY INTERIOR TRIM: FROM $5+
84-87 GAS PEDAL ASSEMBLY GM: $20
84-87 GREY STEERING WHEEL HORN RING: $50
84-87 CENTER CONSOLE ASH TRAY: $30
84-87 HEADLIGHT PARKING SWITCH DIMMER: $25
84-87 RH/LH GREY DOOR PANEL ARMREST: $20 EACH
84-87 GREY LEATHER DASH CLUSTER TRIM (MINOR 1/8 HOLE): $50
84-87 DASH GAUGE CLUSTER HOUSING MOUNT: $40
84-87 GREY 3RD BRAKE TAIL LIGHT: $30
84-87 GREY COMPLETE SHIFTER HANDLE (BOTTOM IS BROKEN BUT GOOD FOR PARTS): $25
84-87 GN DASH PLAQUE (NICE): $100
84-87 GREY POWER SEAT TRIM (NICE): $75
TRANSMISSIONS, SUSPENSION & POSI REARS
84-87 8.5 10 BOLT 3.42 COMPLETE POSI REARS (65K): $1100
84-87 7.5 POSI 3.08 G-BODY REAR (75K): $250
86-87 BRF 200-4R TRANMISSION CORES (COMPLETE): $350
84-87 FRONT OR REAR SWAY BARS: $50 EACH
84-87 GRAND NATIONAL 200-4R TRANSMISSION CROSSMEMBER: $85
86-87 TV KICKDOWN CABLE GM: $75
84-87 200-4R FLOOR SHIFT SELECTION BRACKET: $50
84-87 200-4R FLOOR SHIFT BRACKET (PAN MOUNT): $45
84-87 200-44 DIPSTICK & TUBE (RED OR GREY T-HANDLE): $50
84-87 STOCK UPPER/LOWER REAR TRAILING ARMS: $65 SET
84-87 STOCK FRONT CONTROL ARMS: $20 EACH
84-87 REAR SPRINGS: $25 PAIR
NEW PARTS
84-87 (NEW)GRAND NATIONAL RADIATOR BOTTOM HOSE: $20
86-87 (NEW)GRAND NATIONAL TOP HOSE: $20
86-87 (REMAN) CORRECT A1 CARDONE MAF METER/SENSOR: $115 + CORE
AFTERMARKET PARTS
84-87 9" CONE K&N AIR FILTER (FAIR): $20
84-87 HAYDEN TRANSMISSION COOLER WITH MOUNTING HARDWARE: $25
MICKEY THOMPSON ET STREET DRAG SLICKS 28 X 12.5 X 15 (50% LEFT): $150
AUTOMETER 2 5/8 (MECH) SPORT COMP FUEL PSI (0-100) & OIL PSI GAUGES W/ MOUNTING CUPS (FAIR): $35 BOTH
HURST BRAKE LINE LOCK/ROLL CONTROL & TRIGGER SWITCH: $35
86-87 KENNE BELL BILLET UNDERDRIVE CRANK PULLEY (5"): $50
86-87 PRECISION TE60 TURBOCHARGER. 3" INLET, 3 BOLT, .63 A/R EXHAUST. NO WASTEGATE. NEEDS REBUILDING: $200
84-87 GN CHROME BATTERY HOLD DOWN INSERT: $15
AND MUCH MUCH MORE!!!!
CHECK, MONEY ORDERS, AND PAYPAL ARE ACCEPTED.
ALL PRICES DO NOT INCLUDED SHIPPING.
Old 11-11-2008, 11:19 PM
broke1 broke1 is offline
broke1 is on a distinguished road
Default Re: 1984-1987 buick grand national t-type gnx tta ****new & used parts****
What NOS parts do you have that you want to get rid of???
VERY interested in any NOS parts...
Old 11-13-2008, 02:33 PM
sorry no nos stuff for sale at this time.
thanks
mike
Old 11-14-2008, 08:30 PM
GNsniperdfa1 GNsniperdfa1 is offline
GNsniperdfa1 is on a distinguished road
I have an 87GN,
Whats the total for the Turbo oil line feed, and the KN cone filter shipped to 60660.
Thanks
Old 11-18-2008, 01:15 PM
yamahalic63 yamahalic63 is offline
yamahalic63 is on a distinguished road
any 4.1 stuff??
Old 11-18-2008, 01:49 PM
06_vrscr 06_vrscr is offline
not an owner
06_vrscr is on a distinguished road
you have a good stock turbo for 86-87
Old 11-18-2008, 02:34 PM
Originally Posted by GNsniperdfa1 View Post
I have an 87GN,
Thanks
I sold the k and n filter but i have another that is in fair shape. I can do them both for $40 shipped
Old 11-29-2008, 05:19 PM
The list was just updated.
New parts added, many parts were sold!
Thanks
torquemonsterz
Old 12-21-2008, 01:17 AM
dtodd dtodd is offline
dtodd is on a distinguished road
I own an 86 t-Type. I am looking for a left side stock header, no cracks. Would you have one? Thanks.
Old 12-22-2008, 12:11 PM
T-TopFlyer's Avatar
T-TopFlyer T-TopFlyer is offline
T-TopFlyer is on a distinguished road
Do you have any b-pillar trim in decent shape for a t-top car? Also the 1 and 3/4" trim that runs along the tops of the doors on a limited? And the stick on beltline molding. Especially need the right rear 1/4 piece but am interested in any pieces if they are decent.
beltline trim pic here:
http://www.turbobuick.com/forums/par...e-molding.html
Closed Thread
