Old 05-25-2009, 04:50 PM
nixturbosix nixturbosix is offline
nixturbosix is on a distinguished road
Default vacuum lines for boost solenoid
On the vacuum line that comes from the boost solenoid it tees off and one goes to the turbo and one goes to the waste gate actuator. and i know one has a orifice inside the vacuum Y so does the orifice side go to the actuator or the turbo itself?
Old 05-25-2009, 06:01 PM
Default Re: vacuum lines for boost solenoid
http://www.gnttype.org/maint/quickref.html
Old 05-26-2009, 08:35 AM
thanks phil
Old 09-18-2010, 08:44 AM
bigman bigman is offline
bigman is on a distinguished road
I just got my gn and i'm still trying to learn about the car doing a lot of research . Q; my boost solenoid isnt hooked up their is a 90 degree fitting on the tubing that goes to the wastgate is this correct or should i hook up the solenoid? thanks
Old 09-18-2010, 10:04 AM
how much boost is it making? Lets see a pic of your setup
Old 09-18-2010, 10:09 AM
it shows on the dash a meter that reads 15 or 16 and it goes all the way up. And the 90 degree elbowthe vacum line goes straight to the wastegate .
Old 09-18-2010, 10:14 AM
you need an aftermarket boost gauge, the factory one isnt accurate
Old 09-18-2010, 08:35 PM
how about the line coming from the 90 going to the wastegate is this fine or do I need to hook it back up to the solenoid on the right valve cover?
Old 09-18-2010, 08:59 PM
post up a photo of what ya got going on
Old 09-19-2010, 08:21 PM
ok will get one tomorrow thanks guys
