Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Wheels/Tires
Old 10-08-2009, 12:24 PM
Lightbulb What will fit on the back?
If you want to figure it out for yourself, here is the strategy straight from Summit: http://www.summitracing.com/expertad...chQuestion=907
Note that if you remove your wheel lip trim or roll the inner edge of your wheel well a bit, it will make a difference. To go really large requires wider wheels, frame notching, wheel well widening, etc.
Old 11-19-2011, 10:12 PM
cocarter1 cocarter1 is offline
cocarter1 is on a distinguished road
Default Re: What will fit on the back?
FWIW, I have Michelin Pilot Sport 295-30-19 on rear (Corvette 10" wide wheels with spacers). Had frame shaved (by Jack Cotton) and trimmed wheel trim. There is room for 325-30-19's in rear on 11" wheel.
Conrad
84 GN, 87 power, Original owner. RPE engine, Champ Al heads/r intake, Turbonetic 66 BB, CAS V1, Aeromotive fuel system, HRParts Insane r ctrl arms/sway bar, B-body spindle, Hotchkis ctrl arms/sway bar, Vette 18/19 wheels, QA1, GNX dash, FAST EFI.
Old 11-20-2011, 03:12 AM
Exclamation Re: What will fit on the back?
Why?
With that much work, it doesn't "fit". The car has been redone to fit the tire and wheel. Not really the info that people are looking for.
Old 03-28-2012, 10:05 AM
Troy Shade's Avatar
Troy Shade Troy Shade is offline
Troy Shade is on a distinguished road
i see there hasn't been a posting to this in awhile but thought people might be interested to know. when i got my t, it had 295/50/R15's on a 10" corvetter rallys. i dont know what the spacing dimensions were, but they did have a 7/16" spacer between the wheel and hub. you can see them on my pics. they look really impressive and people thought it was mini tubbed considering the tires were over a foot wide. i had a few issues with them. the passenger side caught on the outside rubbing the wheel well lip. as scott suggested, i could have rolled the lip and stopped that from happening. they also had a problem being off center. the spacer didnt have a lip for the rim to align to as it does with the rim to the hub. and as with the age of the car and having all original rubber bushings, it allowed the rear to move around and rub the frame slightly. maybe if someone wanted to replace all the bushings and machine a spacer with an alignment lip and also to add air shocks or airbags and rolled the fender lip, then they probably would have been ok. since i plan on driving the car i took them off and went back to the original aluminum wheels
Old 03-30-2012, 09:45 PM
Supercomp729l Supercomp729l is offline
Supercomp729l is on a distinguished road
I have tested with my customers cars, here are some of the sizes I have found. It is the frme rail in front of the diff.
15-8 4.5 BS 28 -9 -15 1/4 spacer
15-8 4"bs to close to the wheel well lip.
16-8 4.5 BS 275-50-16, fits with 1/4 spacer
19-9 285-35-19, fits in wheel well but will rub with min diff moveement.
So all of my stuff is 15-8 and use 1/4 spacer.
28-9-15
275-60-15
Tom
Old 12-31-2013, 12:28 AM
black87buick black87buick is offline
black87buick is on a distinguished road
Link is no longer valid.
<profoundly ambiguous quote here>
-Chad
Garage:
1970 Buick Riviera
1987 Grand National
