Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Cooling Systems
Old 07-02-2010, 12:35 PM
Sheriff_Austin Sheriff_Austin is offline
Sheriff_Austin is on a distinguished road
Default Re: Fan Blower?
After looking at that last diagram, that was going to be my first stop :-)
Thanks Tom.
Steve Nichols
Rookie Genius
'86 Buick T-Type
Duttweiler Intercooler
TT Chip
60# Injectors
Comp Cam 206/206
Hotwired Syclone FP
Adj. FP Reg
Hooker 2.5" Exhaust
Old 07-02-2010, 01:38 PM
So pulled the blower motor out...and the space in there was filled with CRAP lol. Pine needles, dirt etc.
The "gasket" for the motor housing was also pretty much disintegrated, so there is air leaking out all over. Cant build pressure if there are leaks, right?
Question -- Is it a gasket? or is it a sealant of some kind? I really couldnt tell since it was pretty much dust when i lifted it off, but it looked like it might have been an actual gasket. Anyone know? I checked napa and rockauto and i only see motors, no gaskets.
Steve Nichols
Rookie Genius
'86 Buick T-Type
TT Chip
60# Injectors
Comp Cam 206/206
Hotwired Syclone FP
Adj. FP Reg
Hooker 2.5" Exhaust
Old 07-02-2010, 04:26 PM
Thumbs up Re: Fan Blower?
I changed out my motor long ago. I thought it was a semi-solid seal, not a gasket. Much like the seal on the heater box when I did the heater core.
I knew I had seen something like that before. Being an amateur radio operator, I bought some of this:
http://www.coaxseal.com/
Rolled up some beads to make seals after scraping off the old ones. Problem solved. Stays semi-soft in all temperatures for a long time.
Old 07-03-2010, 04:42 PM
Ok guys. So I got the motor sealed up all nice...and the airflow is STILL crap.
Is it time to just rlace the motor? Is there possibly a leak in the heater box? I just hate throwing parts at things without knowing why. The blower sounds like it's working. I don't know???
Thoughts?
Steve Nichols
Rookie Genius
'86 Buick T-Type
TT Chip
60# Injectors
Comp Cam 206/206
Hotwired Syclone FP
Adj. FP Reg
Hooker 2.5" Exhaust
Old 07-03-2010, 06:22 PM
Lightbulb Re: Fan Blower?
Tried running with it not in the box? Maybe you can tell more that way.
I'd leave the plugs off until you are under the hood, or get someone to work the controls while you are under the hood. See if the speeds do really change as you flip between different ones.
Maybe the resistor setup is just roasted.
Old 02-14-2012, 05:05 AM
BSofia
Guest
Posts: n/a
oh i've been there!
last summer fan in my car broke and the windows wouldn't open!
the summer was insane (Florida!)
hope you fix this problem man good luck
Old 02-14-2012, 06:06 AM
chrisjkruse chrisjkruse is offline
** BANNED **
chrisjkruse is on a distinguished road
I replaced my blower 2 weeks ago because it was noisy on low speed. The shaft/bushings/bearings? wore out and it needed to run on high speed to balance out.
For about 30 bucks it can be purchased at Autozone and it is the entire assembly with the motor and blower wheel.
Clean the OTHER SIDE of the EVAPORATOR COIL, you will may surprised how clogged it can get.
