Old 01-10-2006, 07:34 PM
Default How do I hook up an aftermarket Tachometer?
Q: How do I hook up an aftermarket Tachometer?
A: If this is an 86/87, there is a green connector with a spade connector on the driver's side of the engine, roughly behind the A/C compressor. That has a 5v squarewave tach signal on it. It may take a 10k resitor between that and ground to work with some tachs.
Old 01-10-2006, 08:46 PM
Default Re: How do I hook up an aftermarket Tachometer?
its the only green connector that has 2 wires at the connector
Old 01-10-2006, 09:50 PM
Exclamation Re: How do I hook up an aftermarket Tachometer?
It may be the only green connector...
Some tach's require modification as well. Such as VDO units. If your vendor doesn't do it, VDO might. See http://www.gnttype.org/techarea/bodygauges/vdotach.html However, some said this was no longer available. Check with VDO first.
Old 04-06-2007, 11:57 AM
86TURBO 86TURBO is offline
86TURBO is on a distinguished road
In regard to hooking up an aftermarket tach, my AutoMeter Sport Comp tach required that you cut a wire inside the tach for 6 cylinder operation and I wired it right into the green tach lead connector.
Vinny
1986 Turbo T-Type
Old 04-21-2007, 10:45 PM
DaveT DaveT is offline
DaveT is on a distinguished road
With my auto meter ultra lite it just had little switches that you set for 6cyl 4cyl 8cyl etc... works great for me
