Old 01-02-2009, 07:26 PM
broke1 broke1 is offline
broke1 is on a distinguished road
Default Re: 200-4R Rebuild ... step by step!
How do you dual feed the direct clutchs?
Old 01-15-2009, 11:47 PM
jakeshoe jakeshoe is offline
The Trans Guy
jakeshoe is on a distinguished road
You leave off the center sealing ring in the direct drum (actually on the drum), and the 2nd sealing ring on the center support, and then block the bolt that goes in the reverse passage by welding the hole up.
But you MUST use the billet forward drum, or the first time it WOTs from 2nd to 3rd, it will snap the shaft.
Old 03-18-2009, 02:43 AM
The Trans Guy
Congrats,
You now have an almost bare case. Be sure to install a new case bushing, and remove the case to lowclutch housing cup plug seal. Clean the case thoroughly, check for cracks, flaws, and stripped bolt holes.
Step by step re-assembly of the 200-4R.
Once your sub-assemblies are built you can begin re-assembling the transmission.
Now is a good time to let the friction clutch plates and band begin to soak in ATF.
The first thing you want to do after the case is cleaned and rear bushing replaced is to be sure a yoke will slide into the output bushing. It is easy to burr the bushing on install and once you assemble the 200-4R, you cannot access the bushing to deburr or replace it without complete disassembly.
Install a new rear seal.
Then positon the case to rebuild it. The preferred method is to use a bench mounted trans holding fixture. However you can set the case on an elevated platform with a small hole that allows access to the rear area for the output shaft to protrude.
There is an output shaft positioning tool that will make assembly of the rear portion easier. It is shown here:
Old 03-18-2009, 08:55 PM
gn-84 gn-84 is offline
gn-84 is on a distinguished road
i would be very greatful to see the rest of the article
Old 03-19-2009, 04:03 AM
The Trans Guy
It allows adjustment to properly position the output shaft so that it cannot move while you are trying to assemble.
Before you assemble the parts into the rear of the trans, you need to check rear endplay on the bench. Completely assemble all parts as shown below. Once it is assembled you can check the rear endplay using a feeler gauge, adjust endplay by changing the selective washer, and then assemble into the case.
Begin assembly by positioning the output shaft vertically. An old yoke can be put in a vise or welded to a bench to make this easier.
The install the output ring gear if not pressed onto the shaft as most are.
Next install the rear torrington bearing. This is easy to forget.
Next install the 4 tang thrust washer on the back of the rear planetary carrier. Retain with petroleum jelly or trans assembly lube.
Old 03-19-2009, 04:06 AM
The Trans Guy
Install a torrington bearing in the front side of the rear carrier. There is usually a plastic thrust washer here. Do not use it, replace it with the torrington bearing as GM did on the later model 200-4Rs.
Install the low roller clutch (sprag) and then the inner race by turning. The race should have the splined side up.
Install the carrier into the rear ring gear:
Now you can install the low support onto the rear carrier.
Old 03-19-2009, 04:12 AM
The Trans Guy
Next install the thrust washer on the rear of the sun shell, and install the sun shell and gear into the low support and over the output shaft. Spin until it seats
Now install the front sun gear with the grooved side down against the sun shell snap ring.
Then install the torrington bearing.
Old 03-19-2009, 04:15 AM
The Trans Guy
You are ready for the front planetary carrier now. Spin it on until it seats.
Install the torrington bearing on top of the carrier.
Now install the input ring gear, thrust washer, selective washer, and snap ring.
Old 03-19-2009, 04:17 AM
The Trans Guy
Check endplay with a feeler gauge between the snap ring and selective washer. .005-.010" is ideal here. Take the time to get it right.
You are now ready to disassemble the rear section and install it in the case.
Disassemble it to the rear planetary. Set the output shaft, rear ring gear, and rear carrier assembly in the case. Position the output shaft using the tool or other means so that the ring gear lugs line up with the parking pawl.
Old 03-19-2009, 04:19 AM
The Trans Guy
Now begin to install the low/reverse clutch pack, begin with a steel plate. Then a friction, and alternate until you end with a steel plate. There should be 6 frictions and 7 flat steels. Once you install the last steel, install the cushion plate.
Now install the case to support snap ring. It is a very thin flimsy ring.
