Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Add-on Electronics and Electrical > Scan Tools
Old 08-05-2007, 07:59 PM
Default an excellent write up how to read boost w/ powerlogger
http://www.vortexbuicks-etc.com/PowerLogger.htm
this was done by my friend Steve Wood
Old 08-05-2007, 08:53 PM
Default Re: an excellent write up how to read boost w/ powerlogger
Scott can you make this a **sticky
Old 08-05-2007, 11:27 PM
Thumbs up Re: an excellent write up how to read boost w/ powerlogger
Done. Great info!
Old 08-07-2007, 10:52 AM
ryan87gn ryan87gn is offline
ryan87gn is on a distinguished road
What about the red wire that was attached to the light green wire? What does that attach to? Thanks.
87 GN, GT3255E, SMC Alcohol Injection, Mototron 60# Injectors, XP Fuel Pump, Fuel Enhancer, Kenne Bell Ram Air, 3" DP, LS-1 MAF, 3 1/2" MAF Pipe, TurboTweak Chip
Old 08-07-2007, 12:01 PM
Now, to begin connecting the MAP to the Power Logger Analog Input Block1) Locate the the light green wire in the wiring bundle. It is the signal wire coming from the MAP and going to the LED boost gauge. Tee a wire into it. If you look at the picture and see the black tape, then you will see the red wire I soldered to the green wire. If you have some quality wire taps, you could use them to make the Tee connection rather than soldering. Note that the green wire does not need to be cut, and, the LED gauge will still work...particularly if you use the rebuilt boost gauge and tach from Caspers.
Old 08-07-2007, 12:19 PM
Thanks, yes I got that piece. I spliced a red wire into the light green wire. What does the other end attach to? All I see is Analog Input Block. Is this an obvious place on the powerlogger that I connect to?
Old 08-07-2007, 12:51 PM
Yes, it is.
Old 08-07-2007, 02:44 PM
Originally Posted by Keller
Yes, it is.
Ok...I'll look tonite. Thanks.
Old 08-07-2007, 02:52 PM
Dixiesys's Avatar
Dixiesys Dixiesys is offline
Grumpy Redneck
Dixiesys is on a distinguished road
Send a message via ICQ to Dixiesys
If it weren't 98 freaking degrees with 97% humidity outside I would be doing this RIGHT NOW but instead I'm hiding inside trying to stay cool, my god it's HOT out there
Very good write up, I'm printing it out now and will probably do this asap (as soon as I won't die of heat stroke trying to do it haha).
Old 08-08-2007, 05:08 PM
Dixiesys's Avatar
Grumpy Redneck
moved to: http://www.gnttype.org/forums/showth...8244#post38244
